Early Manual Transmission swapped into a late model??
My automatic transmission has went bad in my 1988 Porsche 944 N/A. I have a 1985 (early) 944 N/A as a parts car. I know some things can interchange and some cannot. Can I take the manual transmission out of the early and put it in the late? Would this work? Would I need any additional parts for this swap?
Old 12-06-2016, 10:04 AM
The trans will fit/work but you won't have a speedometer drive signal.
Old 12-06-2016, 10:22 AM
Is there any way to get the speedometer to work?
Old 12-06-2016, 11:24 AM
Pauld_94S2's Avatar
How much do you want to spend?
It could easily cost as much as buying the right transmission to begin with.
The 85 trans has a mechanical cable speedometer drive, the 88 is electronic.
Old 12-06-2016, 11:40 AM
Are you saying it's gonna cost a lot to make the speedmeter work? What would I need to make it work?
Old 12-06-2016, 11:58 AM
you buy this kit, but for the same cost you could just find a late 944 trans.
https://www.lindseyracing.com/LR/Parts/968SPEDO.html
kevingross's Avatar
Um, not so fast. The '85 probably has a case that is machined to take the speedo sender. Take a look at it, where the speedo sender goes. If you find a steel plug with an allen socket head, you're in luck. The plug can be removed, and the sender's needed pinion, drive sprocket, bushing, and sender installed, easy task -- perhaps simply swapped from your current transmission. Alternatively I can provide the parts as good used ones.
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
Old 12-06-2016, 11:59 AM
Where can I find a trans for $170?
Old 12-06-2016, 12:19 PM
where are you located?
Old 12-06-2016, 12:50 PM
Peterstown, WV
Old 12-06-2016, 02:02 PM
Send a PM to Pelican users "gravesjeg" (Maryland) and/or "plyhammer" (Ohio)...I'd bet one of them could hook you up with a late trans for that sort of price.
A regular (open diff) 944 transmission in good shape shouldn't cost much more than $100-$150.
Old 12-06-2016, 02:41 PM
Thanks! I'll message them. Happen to know anyone on the south side of WV.. Like Virginia or North Carolina?
Old 12-06-2016, 02:57 PM
Try Pelican user "kens_74_911s" in Southern Pines, NC.
All 3 of these guys sell 944 parts.
Old 12-06-2016, 03:33 PM
Just remembered about this guy in TN too.
Old 12-07-2016, 06:32 AM
I think I'm just going to swap the transmission in and get a GPS powered speedometer.. Seems like the easiest thing to do.
Old 12-07-2016, 04:26 PM
That sounds way harder than just finding the right transmission and bolting it in.
Old 12-08-2016, 07:13 AM
Tags
early to late , swap , transmission
