Angry Fuel problems suspected
Hey, I am having some problems with the car. Was driving and stopped at a light ans when I went to go, the car died. I am pretty sure it is a fuel problem. When I turn on the key, I can't hear the pump. THere was a new pump installed a few monthes ago. Does anyone have any ideas if it could be something else, or is it probably just a faulty pump?
Thanks for the help.
'83 944
Forest Green
Old 01-12-2003, 05:09 PM
Oh yeah, I also checked the fuse for the fuel pump and it is fine.
'83 944
Forest Green
Old 01-12-2003, 05:10 PM
Roger Hall's Avatar
have you checked the relay?
Roger Hall
81 924 N/A
Some people are like Slinkies. Not really good for anything, but you
still can't help but smile when you see one tumble down the stairs.
Old 01-12-2003, 05:29 PM
No, where is that?
'83 944
Forest Green
Old 01-12-2003, 05:37 PM
Roger Hall's Avatar
The procedure is in the haynes manual. I can look it up if you dont have the manual.
Above the fuse panel there are two rows of relays. If you remove the fuel pump relay and take a paperclip stick it into the two connectors that the hanyes manual says and if the car starts replace the relay. Its a common problem.
Roger Hall
81 924 N/A
Old 01-13-2003, 04:20 PM
Yup, I found that, and thankfully, that was the problem.
Connected the 2 and the pump fired right up.
Thanks for the help
'83 944
Forest Green
Old 01-13-2003, 04:44 PM
Roger Hall's Avatar
Glad to help
Roger Hall
81 924 N/A
Old 01-13-2003, 05:14 PM
fty fty is offline
fty's Avatar
Send a message via AIM to fty
fuel pump relay...left me stranded for hours once...
82' 911 SC"Go Go Green" 87'3.2L,Turbo Brakes,Brake Bias Valve,Fiberglass Front Clip, 16" BBS, Multiple Strut Braces, Re-valved Bilstiens and a few more "Stock" additions. SOLD
04' Audi A4 Avant Quattro S-line- RS6 look alike with half the HP
http://www.eurocompulsion.net
Old 01-13-2003, 05:41 PM
