Side mirror glass
So i purchased a Burco side mirror glass to replace the passenger side glass and on the site it states it for a 84 porshe 944 and the measurements are 3 3/8 X 5 7/16
clearly the glass is to small
my car is a NA 84 944 and the backing piece comes on and off i thought i would have to take the whole side mirror off but i didn't
1984-944 NA (Project)
Old 12-26-2016, 09:57 AM
Pauld_94S2's Avatar
You need the Burco 2814 (flat mirror, driver or passenger side) or the 3614 (convex, passenger side).
Old 12-26-2016, 10:45 AM
9FF 9FF is offline
9FF's Avatar
No affiliation <only944.com>
Buy from someone who knows our cars and mistakes like that are rarely made.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 12-26-2016, 10:57 AM
Pauld_94S2's Avatar
There's something weird here.
The Burco online catalog specs a 2812 for 83-85, and the 2814 for 85.5 and later.
I thought the flag mirrors were the same size on the entire 944 series, but Burco shows it smaller for the 85 and earlier model, but I may not be remembering it correctly.
Either Burco is wrong or the mirrors were changed on your 944?
Old 12-26-2016, 11:14 AM
Thanks guys i'll try the Burco 3614 mirror
only944 list the mirror as fitting all 944 82-91 and its a Burco brand it saids fits all flag style power mirrors i don't think mines are power though.
Old 12-26-2016, 11:31 AM
Pauld_94S2's Avatar
Burco 3614 mirror is for passenger side only.
It is convex, everything looks smaller.
Just checking!
Old 12-26-2016, 12:43 PM
yes i order the a Burco 3614 off ebay for $17 i need it for the passenger side in the description it said it was a bigger size than the previous one i got so i'm sure this one will fit
thanks pauld
Old 12-26-2016, 02:06 PM
Just curious, what adhesive can you use to glue the glass back onto the factory mounting part?
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 12-27-2016, 09:41 AM
The mirror glass came within they circle sticky things that goes on the backing all the instructions says and clean off all the broken glass and whip with alcohol they apply the adhesive pads...when I get home I'll take a picture of the pads
Old 12-27-2016, 12:55 PM
FrenchToast's Avatar
Only thing that ever changed in the mirror glass is the use of a convex mirror for passenger side starting in 1988. The size is the same for all AFAIK.
The internal mechanism and attachment method (pins vs. bayonet IIRC) did change though, in 1985 I think.
Old 12-27-2016, 04:14 PM
If you are looking to convert to the convex glass on an older car, you can just stick the new glass over the old glass with the adhesive pads supplied. The extra thickness of the old glass is barely noticeable. There is no need to bust up the old glass and break your power mirror in the process.
If one of the original mirror glasses falls off and doesn't break you can use RTV to reattach it.
While we are on the subject does anyone know of a kit to rebuild either the electric mirror or the day/night mechanism on the center mirror?
Old 12-28-2016, 06:38 AM
