Auto to Manuel...
How hard would it be to swap transmissions on my 88' 2.5? Has anyone done it
Old 01-12-2017, 08:46 PM
rufrob's Avatar
Search, search search and yee shall find. Tonnes of write-ups out there.
Never give up
Old 01-12-2017, 09:58 PM
mhariush's Avatar
are you swapping from manual to auto or auto to manual? I see you have another tread looking for an auto transmission.
Where are you located?
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 2006 Cayenne, 80 924 Turbo, 69 Beetle
instagram @mhariush @technikercompany
http://stores.ebay.com/Techniker-Parts/
Old 01-12-2017, 10:54 PM
I'm swapping a manual into an automatic car now. There are definitely other threads here about it, but it is made a great deal easier by having the donor car on hand. I guess another option would be to find one at a local pick-and-pull yard.
The original question was "how hard is it to do?" It's a sizable job and takes considerably longer than, for example, a clutch replacement.
I now have a spare auto trans I plan to sell at some point.
Old 01-13-2017, 09:08 AM
flash968's Avatar
wow - that's serious commitment.
you can basically buy these cars for my bar tab nowadays. long before i contemplated converting it, i would have just sold that car and gotten one with the trans i wanted already in it, swapped over whatever i wanted to keep from car 1, and been done with it.
have fun.
Old 01-13-2017, 09:29 AM
You'll have to ask Manuel..
Old 01-13-2017, 09:49 AM
Bradical's Avatar
have fun.
There is often a common theme with your advice- it's the most sensible answer!
1988 924SE
2016 STI
PCA - Florida Citrus Region
https://instagram.com/bradical924/
Old 01-14-2017, 05:54 PM
Why change the tranny especially from which I understand there is nothing wrong with the one you have in it, and the automatics are more rare from what I've read. I have an 88 924S myself and wouldn't dream of swapping it out. Though I'd love to find out exactly how many 88 924S automatics were produced for the USA market. I know how many total were shipped for the USA, but that was all the info Porsche could tell me.
Old 01-14-2017, 06:18 PM
rufrob's Avatar
I did the job. I had an 89- 2.7 auto. I swapped it to a 3.0 S2 manual. If just to swap auto to a manual I would not recommend it. Good clean autos sell for the same or more than a rough manual. Consider turbo or supercharging the auto to have more fun.
Never give up
Old 01-14-2017, 07:34 PM
rufrob's Avatar
In fact I did the job twice because the torque tube bearings were bad.
Never give up
Old 01-15-2017, 12:20 PM
flash968's Avatar
based on how fragile i have found the 968 flex damper to be, when the torque of a supercharged 3 liter motor is applied to it, i can't think the weaker 944 auto is going to do well. also, tuning for an automatic with a supercharger or turbocharger is not easy, especially with only 3 gears. it is extremely easy to go lean under boost, and all sorts of bad things happen. you would easily be looking at $10k to do it right, and even then, i'm not sure the auto is up to it. you could end up with a very pricey doorstop
Old 01-15-2017, 01:11 PM
rufrob's Avatar
I thought the dampers deteriorated with age more than use. There is a regular clutch disk conversion option too.
Never give up
Old 01-15-2017, 09:56 PM
A Rouge Tuning MAF is a nice upgrade to an automatic. It is my daily commuting car, however it doesn't do so well in summer heat.
Old 01-16-2017, 03:56 AM
flash968's Avatar
rufrob - i would have thought that too. however, we ripped the brand new one too. 2 disks in the same car. in the end, we had to detune the kit.
i've not felt such a converted 944, but at least on the 968, as for the "regular clutch disk" option, i tend to suspect that the resultant vibrations would not be pleasant. the rubber is there for a reason. even with the rubber, the tiptronic vibrates quite a bit at idle. it does it so much that the tiptronic uses different motor mounts than the 6 speed.
a whole lot easier, and likely less expensive, just to buy a car that has what you want, than to try to convert one.
Old 01-16-2017, 06:23 AM
rufrob's Avatar
20/20 hindsight I would agree it's not worth it. However if you have the time, experience and parts it's quite doable. In anger I could remove a transmission and torque tube in 30mins. Total 1 hour to get the clutch out. And that's on my back on gravel with hand tools. Where there is a will there is a way.
Never give up
Old 01-16-2017, 12:20 PM
i am in southern Cali
Old 01-23-2017, 05:34 PM
flash968's Avatar
all the way from columbia?? wow.
Old 01-23-2017, 07:53 PM
