Self-Proclaimed Newb
Brozoar's Avatar
Send a message via Skype™ to Brozoar
951 Radiator Removal From The Top?
I have to replace the radiator on my 951 (just got a brand new Wizard Cooling unit - sweeet). And boy, would I ever like to replace it from the top.
Does anyone know whether that's doable if I remove the nose panel and intercooler first? I'm well aware that most people come at it from the bottom, but there's some weirdness with one of my PS hoses being looped around an oil cooler hose, and I'd rather not have to disconnect one or the other to unloop them and give me the space I need to get the old rad out.
TIA!
Current: 1986 944 Turbo - Sapphire
Past: 1983 944NA - Black (RIP)
1985.5 944NA - Guards Red (in purgatory)
1985.0 944NA - Maraschino Red (traded for a Volvo 244 )
Old 01-21-2017, 02:25 PM
Not sure what the issue is, it comes out the top just fine. I seem to recall it goes like this.
1. disconnect all coolant hoses and remove
2. remove water-pipe across top
3. disconnect 3 wires from radiator (2-fans, thermo-switch)
4. remove power-steering cooler bracket bolts and let hang
5. unbolt fan-assembly and remove out top
6. unscrew two pinch-bolts from top of radiator all the way
7. push down radiator top and tilt towards back of car
8. pull radiator up and out
Old 01-22-2017, 01:03 PM
Administrator
Dmitry at Pelican Parts's Avatar
TIA!
Hello - if you're still looking for a guide to replace the radiator, check out the below link for one of our site's DIY tech articles. I hope it'll help you with the work. If you have any further questions, feel free to post a Comment just below the article and someone will get back to you with more detailed info. Best of luck!
951 Radiator Replacement
-Dmitry
Old 02-09-2017, 02:57 PM
Brozoar could you do me the favor of measuring the overall width and height of your stock 951 radiator?
Old 02-09-2017, 07:18 PM
I got my fan assembly out the top. Had use a similar process as Dano described.
Old 02-10-2017, 09:44 AM
84 Black, 87 951
I just replaced my radiator in my 87 951 and did it from the top with intercooler left in place. Tight fit but a helper on top and myself underneath to guide into place. I replaced the rubber parts under and on top of radiator. PO had a N/A radiator in it so I changed it out.
Old 02-20-2017, 05:44 PM
Can you post pics of the new and old units side by side, please?
Old 02-25-2017, 04:34 PM
