-   -   Headers question (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/944526-headers-question.html)
911lnv87 02-01-2017 08:05 PM
Headers question
Dear All, my 951 1986 with 75K miles headers are leaking as per my mechanic so i was wondering what were my option and what really was the issue if it is minor leaks.
My understanding is that i am loosing some power... and it smell bad in the car?
Sorry for my ignorance.
Dr DIY 02-02-2017 04:43 AM
On my NA car my factory headers were badly cracked. I have read that this is not uncommon. I intend to weld them up before reinstall. Not sure if the turbo suffers the same but certainly a place to look.
v2rocket_aka944 02-02-2017 07:05 AM
well, you could cut out the bellows and fit a new expansion joint...
cut out the bellows and fit a "slip coupler"...
or try these out... :)
http://www.ebay.com/itm/like/172443163695?lpid=82&chn=ps&ul_noapp=true
911lnv87 02-02-2017 07:30 AM
Hi Both, thanks for the answers, but since I am not that handy I am not sure I could do this... What do you guys think about going with a used part? and getting it install, knowing that I do not track my car and just use it as a daily driver.
Fast Freddy 944 02-02-2017 08:33 AM
New gaskets? You might try stage 8 fasteners, I'm not sure if they make them for the 951? but you could look into it with a new set of gaskets.....also check for oil leaks at the cam box. Mine was dripping on the exaust and it stank up the cockpit also......
Tom944 02-02-2017 12:40 PM
Ask your mechanic to show you where the leak is and post some pictures.
911lnv87 02-02-2017 12:53 PM
Hi Tom, my mechanics told me that it was at the bottom of them...where they connect to the exhaust not at the top where they connect to the engine
Tom944 02-02-2017 01:22 PM
I have no expertise on the 951, but if it was mine I would try and identify if the leak was just the gasket/joint or the actual header itself.
911lnv87 02-02-2017 01:34 PM
Tom, you are probably right but I am not mechanically inclined enough to do so...
v2rocket_aka944 02-02-2017 02:00 PM
forgive me, i had you mixed up with another fellow...
http://rennlist.com/forums/924-931-944-951-968-forum/502791-what-did-you-do-to-your-924-944-today-528.html
DannoXYZ 02-04-2017 05:37 PM
Could be as simple as two new gaskets where the headers join crossover.
