Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
86 944T Alarm
I went to check on my 86 944T and the alarm was going off... It has been sitting in storage for a couple of months now with a 2A battery tender on. I tried turning on and off the alarm with the key but it still goes off when you open the door or try to start it.
I pulled the connections at the key switch and connected them together to complete the circuit but to no avail.
Any suggestions?
Old 02-12-2017, 03:47 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Anybody
I had the hood open while the charger was on. Could this set the alarm off? it was for a few months.....
Old 02-14-2017, 08:35 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
In the Fires of Hell.....
kdjones2000's Avatar
Yes, the hood will trigger the alarm.
'88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG
3300 lbs, 256 RWHP, 15 psig boost
"Certified National PCA Instructor" Hoooohah!
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
Old 02-15-2017, 04:48 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
I disconnected the battery and have it charging. When I reconnect the battery is there any tricks to resetting the alarm system??????
Old 02-15-2017, 06:04 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
We inherited this car from my late father in law. It was his baby and now it is ours. Notwithstanding the alarm issue, I am trying to learn as much about it as possible. He put a performance chip in it but again, his untimely death left a lot of unanswered questions. Thanks for all the help!!
Old 02-15-2017, 06:13 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Nothing to reset. It goes on with the key, and off with it.
Old 02-15-2017, 07:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
Thanks for the info KD.. I will see if the charging of the battery and reconnection does the trick this Sat... It is supposed to be mid 50's here in MN so I may take it for a ride... Wish me luck!
Old 02-15-2017, 07:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
campbelljj's Avatar
Pull the alarm relay and jump two terminals. It's located in the forward passenger footwell under dash area. Sorry I don't have specifics for your year but if you search here and on clarks garage site you should quickly find a good reference.
Old 02-16-2017, 02:07 AM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
Hi Paul, The link below is from Clark's Garage and shows how to bypass the alarm on your car. If you know when the last Cam and Balance Shaft belts were changed you'll be money ahead. The general rule is 30k mile or 3 years whichever comes first.
Alarm System - Bypassing
Cheers,
Larry
Retired USAF and Civil Service,
1985.5 NA Graphite Metallic, A never ending work in progress,
1992 968 Horizon Blue Cab "New Toy"
Old 02-16-2017, 07:53 AM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
Grandad, Thanks for the advice! I will look at the records and see if this was done. The car has 115k miles so I think that might be a good thing.
Old 02-16-2017, 06:45 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Campbelljj, The ports to jump are # 1 & 4 and 7 & 8.
Old 02-16-2017, 06:46 PM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
I'll post a picture of the jumpered connector when I get home for reference. It's really simple to do. I eliminated the alarm (that I never used in the 25 years I've owned it) after it got wet a couple of years ago from the usual leaking battery tray area...
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 02-17-2017, 06:04 AM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Use regular spad connectors and slip them into the plug.
host image online
image hosting 15mb
Old 02-17-2017, 05:00 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
Left the car on a 8a charge and reconnected today. The garlic worked !!! No alarm going off didn't need to bypass. Took her out for a 50 mi run and wash. It is supposed to snow this week so ......... another ride tomorrow. Thanks for all the input! As soon as I get a photobucket acct. I will post some pics. It is a beautiful car!
Old 02-18-2017, 03:42 PM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
