will a 924s transmission work in an 83 944
Looking to buy an 83 944 that occasional grinds 2nd gear when up shifting and always grinds 2nd gear on down shifts.
There is minimal play in the shifter so I am assuming the problem is in the trans? If that's the case will a 1987 924s trans work in an 83 944 without any modifications? If so are they geared any differently? Thanks in advance Rob |
Kessel run in 12 parsecs!
Getting old sucks, bring back the good old days, this new stuff is for the birds.. |
I had to put 2nd gear cog in mine many moons ago. It was pretty easy. For me anyway.. Damned thing would grind almost every time. I even stopped using 2nd gear if I could help it.
87 944N/A since 1992 87 944S - Near Future Engine Project Car 88 944S - Current Project 84 928S - Restoration Project |
Yes the 924S transmission will work in the early car AS LONG AS the 924S transmission has the bolt holes for the early 944 transmission mounts which it should.
The 5th gear ratio may be different but it's not a big deal. |
Kings911, where are you located? I have two good early transmissions here in LA.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero instagram @mhariush http://stores.ebay.com/Techniker-Parts/ |
It fits and does have the mounting points for the Transmission mounts. I have a few choices of 944 Transmissions in stock including one from 924S. Send me an email if interested. I am in Maryland and shipping is not bad at all.
Dimi Paralanov Flying Horse Motorsport flyinghorsemotorsport@gmail.com |
