West Central Ohio 45380
plyhammer's Avatar
Oil cooler seals or headgasket here
www.plyhammersparts.com
Old 03-18-2017, 07:41 AM
9FF 9FF is offline
9FF's Avatar
Depends if that came from the oil pan or the coolant tank. Generally, coolant milkshake is from a bad oil cooler seal, oil milkshake is from a bad head gasket.
Mike A
9TECHNIK | TRANSAXLE ÄRA
1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab.
Old 03-18-2017, 07:49 AM
plyhammer's Avatar
Oil pan
Old 03-18-2017, 07:55 AM
plyhammer's Avatar
I guess sons birthday present will wait another week or two
Old 03-18-2017, 07:56 AM
9FF 9FF is offline
9FF's Avatar
Originally Posted by plyhammer View Post
Oil pan
That's disappointing but fortunate that it didn't happen while your son was driving. He might have continued to drive it and wrecked the engine.
Coolant in oil: replace head gasket and rod bearings, use first oil fill as a flush, drain and refill with new oil.
Oil in coolant: replace seals, use water hose to flush coolant system and reverse flush radiator, refill with new coolant/distilled water mix.
Mike A
Old 03-18-2017, 08:12 AM
plyhammer's Avatar
Yep What I thought. Thanks for confirming
Old 03-18-2017, 08:14 AM
plyhammer's Avatar
Prolly best to do it all while I'm on it
Old 03-18-2017, 08:54 AM
Use a leakdown tester to eliminate/confirm head gasket failure. A bad headgasket will show up as bubbles in the overflow tank.
Good luck, George Beuselinck
Old 03-18-2017, 04:02 PM
Pauld_94S2's Avatar
Mark,
FYI, coolant in the oil can still be a bad seal in the oil cooler, just not as likely.
Do the leakdown test first.
Old 03-18-2017, 04:46 PM
Yep. Definitely do the leak down test first.
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 03-20-2017, 11:02 AM
wrench1's Avatar
Hammer,
Do the leak down test first to see if you truly have a blown head gasket.
But, have you thought about the oil cooler itself? If the cooler itself has a leak (hole or crack) once the engine shuts down the oil pressure drops to zero and the pressure in the cooling system will work its way into the oil, instant milkshake.
If you found this quick enough you might not need to pull the oil pan for rod bearings. My oldest sons cooler failed in his 88-944. Replaced the core and took a chance. We won the gamble and he is still driving three years latter with oil pressure between 3 and 4 bars hot.
Good luck with the car but check the core to be sure.
Old 03-21-2017, 08:26 PM
