rear seats...i don't have any
So the 83 944 I bought was about to be turned into a track car by PO.
And while i want to delete everything in the car from AC to the radio the car came with no back seat. I would like to be able to throw my 7 year old in the back for our one mile commute to his school.
1st question----will the back seat from any model year 944 work?
2nd question---is a 3 point belt an easy or possible swap?
Old 03-10-2017, 06:15 PM
In the Fires of Hell.....
kdjones2000's Avatar
3 point will require quite a bit of work to put in, at least for the OEM.
You would do better to look for an aftermarket type that doesn't have the retractor.
Someone posted on here a few years ago about this.
Keep in mind that 3 point rear belts were only available on 88+ 944's, and have special pieces welded into the rear of the car, plus unique rear carpets.
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 03-10-2017, 07:35 PM
mhariush's Avatar
Where are you located? I have some back seats if you're interested. Have both top and bottom's.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 17 Cayenne S, 03 Turbo X50 Aero
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 03-11-2017, 11:44 AM
Yup, if you go with a non-inertial 3-point belt, it's actually a super-easy install. The upper mounting point is present even in the early 944s (my 84 has them)- there's just a plastic screw in the middle of the pillar. Pull that screw, and screw in the upper mount for your aftermarket belt.
The inertial-style is all-but-prohibitively involved- you'd need anchor points welded into the trunk area, different carpet, etc. For what you're describing, I'd absolutely stick w/ the non-inertial.
Old 03-13-2017, 08:06 AM
I have a burgundy leather rear seat, with the 3 point rear seat belts. Comes with matching luggage cover, but does not retract.
Also have a Black vinyl rear seat. Does not have the rear carpet or luggage cover
Old 03-13-2017, 03:16 PM
