Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
Autocross/Hillclimbs
Adjusting rear helper coilovers
So here's something I find no talk of.
I have 30mm bars, and they still squat on acceleration like crazy. So I have put on 150# helpers, and I'm trying to figure out the best way to adjust them. Currently the weight is mostly on the bars still, and the springs are partially compressed.
I guess I'm trying to figure out how much to lift the perches. I suppose it's a matter of set up and not "the right way".
I should be able to compress the springs to an extent without lifting ride height, no?
Ideas?
2x 1984 944 N/A; 1988 951S Silver Rose; 81 VW Rabbit Diesel; MK4 VW R32
President - Bridge City Autosports
http://www.bcautosports.club
Old 03-17-2017, 11:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
no one knows how..?
guess ill toy with it at this next weekends event
Old 03-20-2017, 12:18 PM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Toofah King Bad
Rasta Monsta's Avatar
944 will squat as long as factory rear suspension is in place.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-21-2017, 05:37 PM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
9FF 9FF is offline
Too Many Porsches
9FF's Avatar
+1 Why do you want to eliminate the rear squat on acceleration? it's simply weight transfer and really not bad in a car with static 50/50 front to rear balance. The only adverse affect is that the steering goes slightly light on acceleration. Like Rasta says, you're not going to eliminate that with factory suspension or even by fitting helper springs with t-bars. If you remove the t-bars and fit rear coilovers with very high spring rates that will help, but you will destroy the cars handling in other situations and it will end up being a harsh ride.
Mike A
Current: 1986 951; 1986 944; 1986 944 (Track); 2000 996 (Cab); 2005 CL55 AMG; 2009 GTS V8 (6-Speed).
Past: 1972 RS1600; 1983 E24 M 635 CSi; 1985 308QV; 1985 UR Quattro; 1986 944; 1989 M635 CSi; 1990 560 SEC AMG; 1994 E34 M5 (Track); 2001 461 Puch G; 2002 E46 ACS3; 2006 X308 XJR; 2010 LP560-4 Corsa.
Old 03-21-2017, 06:13 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
ah if only I had pictures on this computer.. ha
with 30mm bars my wheels tuck about 4 inches up under the fender. its not very low either. its a matter of torque, and the tuck is limiting my tire size because of rubbing.
ill see how these go for now.
for track use, the tucking isn't as much of a problem im sure, but I don't track. I mostly autocross, and some hillclimb. its not a streeted car.
in autocross, theres a lot of on and off throttle at 5500rpm, and it causes ridiculous tuck.
Old 03-22-2017, 04:45 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
