Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
924S fog lights
I'm getting ready to install fog lights on my 87 924S. I have the Hella 550 and I bought a factory 5 pin switch. There is already a fuse for the fog lights and I found the wiring on the front end. Will the switch have a plug already on the harness? Are they just plug and play or do I have to modify somewhere?
Old 03-20-2017, 05:55 PM
Politically Incorrect
onZedge's Avatar
If you look under the dash, over the ECU (under the steering column), you will see a double relay socket. Plug in two standard 5-pin relays (or get the factory "fog light relay". Plug in your factory switch into the factory harness socket behind the center instrument console. You already found the wires behind the bumper. Good to go.
Edek
'87 924S
'91 535i
Old 03-21-2017, 06:36 PM
Thanks I'll look today
Old 03-22-2017, 03:29 AM
Found the double relay plugs. Bought a factory relay from flea bay. Now just have to locate the switch plug. Thanks for the adult guidance.
Old 03-22-2017, 05:41 AM
onZedge's Avatar
You might have to do a partial "console-ectomy" to get to the fog light switch blanking plate for removal. The switch plug resides behind that.
Edek
'87 924S
'91 535i
Old 03-22-2017, 06:17 AM
Been there stated as this
Old 03-22-2017, 11:18 AM
Now its like this
Old 03-22-2017, 11:20 AM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
