-   -   Reference Mark Sensor - Flywheel Pin Troubles (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/950827-reference-mark-sensor-flywheel-pin-troubles.html)
Bradical 03-25-2017 02:46 PM
Some may remember, I have been having intermittent issues with my 924S dying while driving. I posted here earlier because I found that the connections at the Speed/Ref sensors were damaged and I redid them. This rectified the problem for a few weeks until it started happening again.
Last weekend the car died after warming up for about 5 minutes and would not restart, no tach bounce. Every other time the car has restarted immediately or after a minute or two.
Using an oscilloscope I found that I had a good signal from the speed sensor a VERY weak signal from the reference sensor, which reminded me- I know the PO had issues with the TDC pin in the flywheel causing no-start about a year before I took ownership of it (we AutoX'd together).
I have done literally everything but pull this flywheel as of yet- new sensors, rebuilt the entire DME wiring harness, new ignition switches, multiple DME relays, DMEs and speed/ref sensors. The entire fuel system is new. The pump runs with the DME relay bypassed... I am just telling you this so no one copy and pastes the typical no-start troubleshooting procedures because I have gone through ALL of it and I know that my issue lies with the reference mark sensor. I read the resistance of the sensor through pins 25 & 26 at the DME connector but I am reading less than a 0.5v peak during cranking. The speed sensor reads the same resistance and shows a perfect 2.5v peak. I have checked, double-checked, set and re-set the sensor gap.
Anyone had a similar experience and can shed some light on this situation? I was able to see the reference mark set screw through the OT mark view hole and it's definitely THERE, but it looked a little rough, like it was stripped. Thoughts?
kdjones2000 03-25-2017 04:38 PM
http://i29.photobucket.com/albums/c2...psdm6hzedb.jpg
9FF 03-25-2017 06:23 PM
Originally Posted by Bradical (Post 9525928)
Some may remember, I have been having intermittent issues with my 924S dying while driving. I posted here earlier because I found that the connections at the Speed/Ref sensors were damaged and I redid them. This rectified the problem for a few weeks until it started happening again...
What did you do when you "redid them"?
How intermittent was it before you "redid them"?
Was it exactly the same intermittent issue when it came back a few weeks after you "redid them"?
When you replaced the DME harness did that include the complete wiring to the sensors?
After you replaced the DME harness was the problem exactly the same?
Do you have an aftermarket flywheel fitted, like a fidanza?
Bradical 03-25-2017 06:39 PM
Originally Posted by 9FF (Post 9526092)
1.) What did you do when you "redid them"?
2.) How intermittent was it before you "redid them"?
3.) Was it exactly the same intermittent issue when it came back a few weeks after you "redid them"?
4.) When you replaced the DME harness did that include the complete wiring to the sensors?
5.) After you replaced the DME harness was the problem exactly the same?
6.) Do you have an aftermarket flywheel fitted, like a fidanza?
I numbered your questions so I can respond to them in order.
1.) I cut back the speed and reference sensor wires and installed replacement connectors. I also re-gapped the sensor bracket and installed 2 new sensors. I also installed a new DME relay.
2.) Completely random. I have had the car shut off a few feet after leaving the driveway, on the freeway at speed after having been on the road for more than an hour, and just a few seconds after startup.
3.) After replacing the connectors, I ran in an AutoX without issue. Then, on the way home the car cut off and restarted after 2 minutes. This was the first time it had happened in weeks.
4.) I made a two hour drive, slept, then woke up and started warming up the car. It ran for 10 minutes, died and would not restart. No tach bounce. Of course I tried everything I could- swapped out the DME relay again, jiggled the sensors connectors, tapped the DME and relay, shook the connections at the DME. Nothing- had to get towed. SO, when I got home I pulled the entire DME harness from the car and replaced the reference sensor and fuel injection harnesses with the ones from Lindsay Racing, so complete replacement all the way back to the DME.
5.) Still no start, no tach bounce. Continuity and signal on 8 & 27 for RPM, continuity on 25 and 26 (1100 ohms) but really weak signal for reference mark. Before anyone asks, YES I did verify that the sensors were plugged into the correct connectors- I checked continuity across pins 8 and 27 at the DME and unplugged the speed sensor (closest to the transaxle) and observed the meter read OL, then reconnected the plug and observed the meter report 1.1kohms. I followed the same process for the reference sensor, a la pins 25 and 26 and the sensor closest to the engine and made the same observation in that case.
6.) No, it's a factory flywheel. I remember having a conversation with the PO before I had any knowledge that I would one day buy the car from him where he told me he had a month-long no start escapade where he found that the flywheel reference stud was damaged during his clutch replacement. I pulled the clutch today and found that the bolts for the throwout bearing guide tube were almost falling out and had scored the face of the throwout bearing, and 2 of the flywheel bolts came out by hand...
On top of that, the reference mark stud was pretty rough on the end and appeared to have been stripped. I was able to drill and extract it FAIRLY easily (this in itself tells me it isn't the factory stud and wasn't installed with Loctite 270) and I had already ordered a couple last weekend when I suspected I might be driven to this point. I am glad that I am doing this even if it ends up being something else entirely if not to discover the fact that the PO has obviously reused or not torqued the flywheel bolts correctly.
thomasryan 03-25-2017 08:03 PM
When you say you rebuilt the wiring harnes, does that mean new ends or new wires?
Are you scoping it at the sensor or at the DME?
Edit: sorry just read your response. Can you put an ohm meter at the DME and manipulate the refrence wire to see if the reading changes. (fixed a knock code on another car with a fresh coax wire recently)
9FF 03-25-2017 09:05 PM
First off I was thinking you had a wiring problem as these sort of intermittent problems are normally always electrical related. I know you replaced the sensor connectors by cutting back to good wiring but the wiring in the looms on our cars may have also degraded somewhat over the years, that's why I asked if you replaced the loom. The sensor wiring may be difficult to measure resistances over if the actual wiring may be suspect, probably causing a higher resistance. I've seen it on the fan resistor wiring but I'm sure it's elsewhere too especially as the resistances you are measuring are quite low.
It seems like you are now digging deeper into this by accessing the flywheel and the stud. Certainly seems like fitting a new stud, if the end is damaged, is the way to go. The stud may also be loose and is backing in or out while the engine is running. It was originally held in by loctite though that may have degaraded, idk if that's common. If the problem persists I would change out the complete wiring from sensors to DME next.
Finally, I know you have swapped out the DME, I presume with another used one. If the used one was a known working one that's fine. However our DME's, as they go through heat cycles, do suffer from solder dry joints, especially on the two internal power circuits. It's a known problem and will cause intermittent no-start problems like you are experiencing. I would suggest you resolder the DME even if it's not confirmed as the problem now, just a wyit as you go through resolving the issue. I would not be surprised if both your old and new DME had dry solder joints, I have resoldered all my (3) car DME's when one failed, they all looked dry. GL
Bradical 03-26-2017 04:19 AM
Yeah, I actually pulled the entire DME harness from the car, stripped off every single bit of wire loom and exposed every wire, replaced the speed/ref sensor harness and the fuel injector harness and reinsulated the whole harness with high quality heat resistant loom insulation and reinstalled the harness. I actually didnt find anything suspect beyond the original breaks in the insulation at the connectors I fixed weeks ago. BUT, I am glad I did it, its really helped my peace-of-mind and it looks great, too!
I have 3 DME's on hand right now (I think I literally keep 3 of almost every part), perhaps today I will flow some solder on one of them while I am waiting for my reference sensor studs and new throwout bearing to ship. Thanks for your insight, it helps to discuss it with people who know what is going on.
Pauld_94S2 03-26-2017 07:55 PM
Before you go too crazy with this problem, would you be able to swap the two sensors since they are the same part?
In my understanding of what you have stated, you have two sensors with the same resistance, as measured from the DME computer, but with unequal pulse outputs.
Switch them and see if the low output follows the sensor or stays with the location.
If the problem follows the sensor, then looks like a defective sensor.
If the problem stays the same, then you may have an incorrect gap between the sensor and the screw.
And this is based on the fact that you have verified the loom wiring is correct.
Bradical 03-27-2017 08:57 AM
Absolutely, yes. The pulse output from the reference position was the same across different sensors unfortunately- the low output stays with the location so to speak.
I will hopefully have the car reassembled this weekend and I will update everyone on what happens. While I had everything picked apart, just to reassure myself I did jump out the pin on the DME plug that grounds the DME relay and the relay engaged the fuel pump and I built pressure at the rail. This issue is certainly the DME not having the qualifying triggers to start- testing it that way seems to me to include every related component and wire excluding the motronic computer. There's simply no where else to take this but to the flywheel pin at this point! (I hope! Ha!)
Bradical 04-02-2017 02:10 PM
Jeeze, so the odyssey continues. I set a factory pin in the flywheel at 5mm and reinstalled it, still no start. I proceeded then to completely dismantle my dash in search of an electrical issue. Obviously when I reinstalled the bell housing I took great care to re-check and re-set (this makes 4 I think) the sensor clearance.
Here's what I have SO far.
1.) Sine wave on the speed sensor
2.) Start signal from the ignition switch to pin 4 (~10vdc)
3.) Activation of the 1st coil on the DME relay
4.) Power returning to the DME on pins 18 & 35 from the DME relay
What's not happening.
1.) Activation of ground to 85b from pin 20 (if I jump out pin 20 to ground, the fuel pump runs)
2.) Ignition pulses the ignition. coil from pin 1
3.) Signals to the fuel injectors
4.) TACH BOUNCE! I still don't have tach bounce.
Note: the stuff the DME computer does when it confirms the engine is being started, or in other words, the stuff that it won't do if it doesn't see speed/ref & start signals.
Oye vey, so I have purchased my very own oscilloscope so I can check the reference mark signal for myself and come to my own conclusion because this has to be, somehow, the source of my troubles and if not I need to definitively rule it out. At this point I would be 100% convinced that I had a bad DME computer, HOWEVER, I have tested 3 known good DME computers on this car to absolutely no avail.
On a good note however, man am I lucky that I ended up pulling this flywheel. The PO forgot to torque 2 of the flywheel bolts (or reused old ones, resulting in their loosening), AND the bolts holding the throwout bearing guide tube to the clutch bell housing- resulting in some damage to the throwout bearing- something I wouldn't have found until catastrophic failure... so there's that. I am also taking the opportunity to go through the central electric system as I was insuring I had good signals back and forth between the DME, DME relay and the fuel pump.
kdjones2000 04-02-2017 06:02 PM
Do you have the EMI sleeve, and if so the spacer ring required for the speed sensor?
Bradical 04-02-2017 06:44 PM
I do have the EMI sleeve, no spacer on the speed sensor. Wow, could that be it? That would make the reference sensor too high. Holy hell, I forgot about that- I mean its crazy that it was running without it for a year or more and now it wont, but I am willing to try anything at this point. I am going to order that thing and try it out!
Thanks! This is what I was hoping for- somebody to mention something I hadnt thought of!
Bradical 04-08-2017 10:43 AM
Well, the spacer for the speed sensor isnt the trick. You only need the spacer if you are running an early bracket without the machined recess for the EMI sleeve.
kdjones2000 04-08-2017 04:31 PM
I have that spacer for the bracket on my '88 Turbo, so I don't know where you are getting your information from.
djnolan 04-08-2017 04:47 PM
Lindsey racing sells partial replacement harnesses for the injector harness portion and the sensor harness portion. I have to agree that the wiring and insulation inside the looms could be toast and either shorting in certain conditions or loosing connectivity intermittently.
Also 944online will test your DME, assumedely that is a load test.
Bradical 04-09-2017 08:26 AM
There are 2 brackets. 1 has a machined recession for the EMI sleeve to fit into that does not effect the height of the reference sensor, and the other bracket does not have a machined recession, which causes the EMI sleeve to make the reference sensor sit higher (the thickness of the shoulder on the EMI sleeve) and thus require the spacer to be installed on the speed sensor to compensate.
Thats what I did- and I have 3 DMEs and an oscilloscope- what I am seeing is a strong sine wave from the speed sensor and a weak (0.5v peak) signal from the reference sensor.
What i tried yesterday was cutting a thinner washer for aligning the reference sensor. I cut one that was 0.7mm (instead of 0.8mm, I am using a 0.0001 micrometer to hit within a few 10 thousandths of this measurement) and realigned the bracket. The car started an ran, but scored the face of the speed sensor. Again- I had set the reference pin on the flywheel to 5mm, so everything should be working fine... I need to just pull the engine and check this relationship on an engine stand. Its bizaree that 0.1mm closer would cause damage to the sensor, especially when the factory manual says you should be between .5mm and .8mm. Very odd.
To be totally honest, the fact that the car actually ran was pretty vindicating- it at least proved that all my testing has been right. I am really not sure how or why this issue has come up, but again I do know that the PO wrestled with a problem with the reference sensor pin which he thought he resolved but was one of the influencing factors as to why he sold me the car in the first place.
kdjones2000 04-09-2017 10:31 AM
Hmmmm...
Sounds like if you PUT THE SPACER WASHER on the speed sensor, and gapped things properly, then everything should work as it should.....
If you are worried, the do the above, and slowly hand turn the engine and see if the reference sensor and pin touch.
v2rocket_aka944 04-09-2017 11:40 AM
are all the grounds hooked up at the block/bellhousing?
Bradical 04-09-2017 12:07 PM
Originally Posted by kdjones2000 (Post 9544237)
Hmmmm...
Oh I tried that. I was convinced it would work. The reference pin hit the sensor- also the bracket adjusted all the way down, so I am not sure if the speed sensor was even remotely close enough.
Bradical 04-09-2017 12:18 PM
Yes sir.
There is something not right about the relationship between the positions of the sensors themselves, the ring gear and the pin. I am just going to pull the bellhousing again and possibly the engine itself and check all the alignments and gaps with a feeler gauge. Here's why I am so confident.
Here's the sine wave I am seeing for the speed sensor. It's peak is nearly 8.5v, meaning that it's as close to the flywheel as it could possibly be without touching. In reality this signal can be as low as 2.5v, which a variance in 0.3mm spacing.
Imgur: The most awesome images on the Internet
The reference sensor, on the other hand. The positive flank is only ~0.5v, about 25% of the intensity the DME needs to see to fire.
I feel like the best way to go about fixing this is to dismantle the car and do it right.
djnolan 04-09-2017 01:14 PM
I would try running handmade harness wires for the sensor reading incorrectly back to the dme first to rule out any wiring problems. Whatever you do should include a full ground current return path from the sensor to the DME.
Everytime you pull the engine and disconnect the harness you risk damaging it further by breaking wires or cracking the insulation. At 30 years it is in a fairly delicate and baked state.
The simplest way to gap the sensor is to glue a piece of cardboard of the correct thickness to the end and install it. The cardboard will wear away by itself. Credits to the board for this idea.
djnolan 04-09-2017 01:30 PM
+1: the main DME ground is connected to the bell housing near where the sensors are located. loosen and tighten it to get good metal on metal contact.
Bradical 04-09-2017 01:38 PM
The cardboard deal is a good idea.
My DME harness has virtually no risk of being damaged in such a manner because I fully removed it, replaced nearly all of the wires and connectors and reinsulated the entire thing. I have taken every oppertunity to rule out any electrical issues causing the symptoms I am recording.
Correct. I did that.
Bradical 04-16-2017 11:58 AM
Today I pulled the bellhousing again and replaced the pin. The one I ordered from Porsche is stainless steel- I pulled a regular steel pin (you know, one that can be picked up by a magnet) and installed it. I set the speed sensor gap with a feeler gauge and put the bellhousing back together. No start.
I recently discovered that their are two different speed sensor shims. I purchased one that is around 2mm thick, and of course that caused the reference sensor to collide with the reference pin, BUT the car started and ran!
I have figured out by chance that Porsche actually made a 2mm AND a 0.3mm shim. If I install the 0.3mm shim on the speed sensor, that will mean that my reference sensor will be .3mm closer to the reference pin and that might FINALLY be the ticket. Again, the oscilloscope is showing me a really weak signal on the reference sensor, a 0.5v peak. All of the grounds, sensor sheilds and wiring has been combed through very critically and I found absolutely nothing to be concerned about.
So thats where I am at. If that doesnt work, who knows.
thomasryan 04-16-2017 01:57 PM
IMHO, I still think the wiring from the DME to the sensor plug should be replaced.
Bradical 04-16-2017 02:54 PM
I did replace it, I replaced ALMOST every wire in the harness actually, I mentioned that alittle ways back.
thomasryan 04-16-2017 03:07 PM
I just biased because I have two 'recycleable' soybean harness cars in the yard. Even the cam in the headlight switch crumbles to cut down on that global warming thing.
Bradical 04-16-2017 03:50 PM
No prob. I wish it was the harness... it would be running by now!
Bradical 06-03-2017 03:47 PM
UPDATE! So I pulled the engine so I could check the sensor alignment with feeler gauges and admittedly do some other work that needed to be done.
I added the 0.3mm shim to the speed sensor. For anyone reading this thread in research mode, there are actually two speed sensor shims- a 0.3mm and a much thicker one which I believe is something like 2mm. I set the speed sensor to be exactly 0.8mm with a feeler gauge. This put the distance of the reference sensor to the reference sensor pin at 0.24mm. If the 0.3mm shim wasn't used, the distance would actually be 0.54mm if the speed sensor was set properly.
Before I started I showed a 0.2v positive flank on the reference sensor. When I reinstalled the engine with the new alignment and shim the reading is now ~6.0v (my oscilloscope only goes up to 5v). STRONG! The car starts and runs now.
ISSUE RESOLVED!!
Check out what I see on the oscilloscope for the reference sensor now, and compare it to the link provided earlier in this post- there is a 5.8v difference in amplitude for the reference signal and now its working.
http://imgur.com/a/nDCk8
Soluton - added 0.3mm shim, realigned sensor bracket. strong signal, car runs.
Dan Martinic 04-03-2018 06:06 AM
Thank you for providing this information and images of your oscilloscope.
I have a similar yet slightly different issue. Perhaps your experience can shed some light on what my next step could be.
My car ran fine. I changed my clutch, and in the process I broke and replaced the reference sensors and bracket.
The car will not start. The DME is not pulsing the fuel injectors nor the ignition coil. I have performed just about every test in the DME/KLR Test Plan; everything passes except Test Point #14 where I don't get a signal from KLR Pin 9.
Attached is a screenshot of my speed / reference sensors video while cranking (Speed on top):
http://poormansporsche.weebly.com/up...-7614_orig.png
My reference pin is visible and I managed to measure 5mm depth (a very intimate experience through the TDC hole)
I am using a used replacement bracket with the aluminum sleeve and new 2mm washer, appropriate for my car 1988 951 (indeed, the part number for that washer starts with "951 xxx ..." while the .3mm is "944 xxx ..."
I have measured correct values at the DME harness for the both sensors (ohms).
I managed to borrow a DME that apparently is good; it didn't make a difference.
Oddly, my ignition coil's primary resistance measures *negative* .30.
Thank you for any advice
kdjones2000 04-03-2018 09:28 AM
There is a way to bypass the KLR for testing. I would do that and make sure that the car starts with your DME alone.
The KLR being bad can prevent your car from starting - I had mine go bad and had to replace it to make things good again.
IdahoDoug 04-04-2018 09:14 PM
I am not an expert, having only had my 944 for 9 months. However, I have been through an experience that may shed light. I tested the harness values for both as good and went through the process you describe. Borrowed DME, etc.
After literally days of trying to figure it out, somehow we did not realize that though we tested both sensors and both harnesses, at some point my helper adjusted one of the sensors too close an it got whacked by the metal screw that protrudes out of the flywheel. From then on, that was the problem though we'd both waved our hands over the sensors as fine. It took us many days to restart the checklist and when we pulled the brand new sensors it was bent. So beware of assumptions you've checked something as these sensors can be damaged after you've checked. If too close, one sensor buzzes against the teeth. The other gets instantly broken/bent. I can't recall which is which but I think they're worth a look. Or a re-look.
djnolan 04-05-2018 10:51 AM
I have an intermittent no-start on an 85.5 car. Sometimes I get a no-tach-bounce no-start condition. If I unplug the DME harness connector and reconnect it fires right up. I noticed a little moisture in the connector and I dried it and turned up the heater. Hope no-start doesn't return.
(the DME is laying on the carpet for easy access, due to some swapping of DME between AFM and MAF configurations and may be more susceptible to moisture?)
