Fuel lines labeled to show age?
Just wondering...if there are any symbols/numbers/dates, etc. on engine-compartment fuel lines that will tell me their age?
Old 03-29-2017, 04:15 AM
No. They are probably original, which means they are pushing 30+ years.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 03-29-2017, 06:43 AM
does it have a Porsche part number printed on the hose?
if so...replace.
Old 03-29-2017, 07:22 AM
does it not have a Porsche part number printed on the hose?
if so...replace.
FTFY
www.944ecology.com
Old 03-29-2017, 08:13 AM
Originally Posted by 944 Ecology View Post
is there a fuel hose?
if so...replace.
FTFY
FTFY
Old 03-29-2017, 08:30 AM
Yep, lots cheaper than replacing everything under the hood, including the fuel lines.
www.944ecology.com
Old 03-29-2017, 10:44 AM
If over 30 years old change them or you'll regret it. Seen too many pictures of ALFA's burn't up because of this lack of maintenance. Can't blame it on ethanol, that's "BS" Bet your brake hoses were changed by now, why neglect the gas lines, it's an explosive!
You'll take one out and see if you press the end how cracked they are and how dangerous it is not to replace them.
AlfasRule!
72 Montreal (Da Pumpkin)
75 Alfetta Sedan, 75 Alfetta Coupe Race Car
82 Spider, 84 GTV-6. 84 GTV-6 Verde (GiGi)
87 Milano ( Da Winta Beata)
Old 03-29-2017, 01:19 PM
BoxsterGT's Avatar
Porsche Crest
This is NOT what you want to happen............
I have repair hoses that do not require replacing the complete hose assys......
They are E-85 rated and considered factory level by most who know my work.
Len at Autosportengineering dot com
Old 03-30-2017, 03:48 AM
+1 for Len's solution!
www.944ecology.com
Old 03-30-2017, 05:26 AM
+2
There is usually at least one Melba toast post every year come spring.
Old 03-30-2017, 05:37 AM
How much fer dem purdy hoses ye got there?
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 03-30-2017, 06:18 AM
Toofah King Bad
Rasta Monsta's Avatar
The Bay of Renn also purvey a fine solution.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 03-30-2017, 03:10 PM
BoxsterGT's Avatar
Porsche Crest
These are shown in post #8 above and are for the front of a 924S and 944/1. Hard to show once installed but this is what I have.........
The photos show the replacement E-85 rated hoses installed with 1) Foam Insulation and 2) Aftermarket Insulation the customer provided.
As you can see here.....
the area behind the Brake Booster is tight and not accessible for crimping new hose unless the Booster is removed. To save all this extra work, I have been able to make up longer hoses that connect below the Booster in the area under the pedals & floor boards......
The hardlines are cut and connections are made with Metric Flare fittings and as factory in design & construction. Optionally, I have Metric compression fittings if a flare tool is not available.
Hope this helps.
Len
Old 03-31-2017, 08:42 AM
