Proprietoristicly Refined
John_AZ's Avatar
924S power steering rack and in line PS filter installation info
In 2008 I bought a basic rebuilt PS rack from AutoZone with a Limited Lifetime (LLT) Warranty.
The seals failed in Dec. 2016 and AutoZone did not have the basic 924S PS rack and offered me the upgraded rebuilt PS rack from Atlantic Automotive Engineering (additional $80)--again LLT.
Atlantic Automotive Rack & Pinion AAE3993 - Read Reviews on Atlantic Automotive #AAE3993
Home Page and more info.
Atlantic Automotive Engineering requires a power steering filter.
Very impressed with the rebuilt rack workmanship and a 3/8" inline PS filter is included.
3/8 Inch Magnetic Inline Power Steering Filter
After careful consideration and reading that Arnnworx has a repair solution to the short 3/8" return line to the PS reservoir...
944 Power Steering Cooler-to-Reservoir Hose Repair : ArnnWorx Specialty Tools
...I cut the return line hose under the PS reservoir before the bend about in the middle and inserted the Magna PS filter in the line. It lays on the ledge under the PS reservoir.
I added a piece of rubber under the filter for vibration reduction.
Atlantic Automotive engineering also recommends replacing all PS hoses due to age and contamination of old hoses.
I replaced the main pressure hose ($105 to $150+-) I had replaced the PS reservoir and low pressure hose to the pump a couple years ago.
If you follow Clarks-Garage PS install info, installing the PS rack is straight forward.
WYAIT- new Corteco engine mounts....
J_AZ
1988 924S, 85,750K ..+ 1987 924S, 154K DD (+15K est. bad odo)
Old 04-07-2017, 04:07 PM
Toofah King Bad
Rasta Monsta's Avatar
I don't think I would install a second filter to the system. The one integrated into the reservoir is more than adequate.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 04-09-2017, 12:47 PM
