-   -   Removing spark plugs (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/953573-removing-spark-plugs.html)
DannoXYZ 04-19-2017 10:02 AM
I've had the same set of plugs in my 944na for the past 11-years!!! May be longer as that's how long I've had the car and haven't even changed the plugs. Performance-wise, copper is more conductive than either iridium or platinum. Those are really just for durability and longevity.
dgcantrell 04-19-2017 10:10 AM
Nissan V-6's in some of the small pickups are the worst. I've had to use two 12"extensions, and 2 u-joint adapters to get to a couple of them on that engine....
pfarah 04-19-2017 05:20 PM
Page 90 in the Owner's Manual (1983).
http://forums.pelicanparts.com/uploa...1492647894.jpg
Costan944S 05-09-2017 08:28 AM
Originally Posted by DannoXYZ (Post 9554057)
No, NGK 3517 are BKR5EZ
You want:
NGK (6637) BPR6EIX Iridium
Autolite XP63 Iridium XP
Champion RN8WYPB3 (9804) Iridium
Denso (5305) IW16 Iridium
Denso (4708) IW16TT Iridium TT
So the best NGK spark plug for 16v engine is BPR6EIX?
How about BPR7ES?
Thanks in advance :)
DannoXYZ 05-09-2017 11:52 AM
I read the OP's "'86 944s" to mean plural, or multiple 8v 944. The later 944S 16v models use a colder plug. Here's a listing of compatible plugs: 1988 Porsche 944 S Coupe - Ignition Tune-Up - Page 1
Porsche_Euro 05-09-2017 01:29 PM
Yes, the s meant plural. I have the base 8v 944 in both cars.
