After 9 years, is it time for new? 1984 NA daily driver (spring to fall, no winter). I have Bosch 7mm Silicone High Temperature wires and Bosch cap and rotor, car runs fine, getting average 25-26 MPG driven normally. Should I replace everything being 9 plus years old and if so what brand you recommend?
1984 944 N/A Passadena Gold, No Sunroof 1971 Cuda 440-6, 4 Speed, The Last 440-6 Cuda built, Black 1971 Cuda 340, A/T, Rallye Red 1970 Cuda Ragtop, 383, 4 Speed, Triple Black |
maybe worth changing the plugs (i prefer NGK BPR6ES but others like Bosch equivalent)
if the rotor isn't worn down i'd leave the cap, rotor and wires alone. i've been using the same cap/rotor since 2006 and am still using the original from 1984 plug wires, they haven't given me issues yet. |
