-   -   Wiper motor help needed, wipers not parking. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/95425-wiper-motor-help-needed-wipers-not-parking.html)
AaronM 01-23-2003 06:18 PM
The wipers on my 1987 924S stoped parking properly. How do I adjust the mechanism so that the wipers park in the proper place? They currently park at about three quarters of the way from full "up". The motor was replaced about a year ago according to the maintenance records I have, and even when I got the car the wipers would only park in intermittant (which they have now stopped doing too.
Is it even possible to adjust this, or is it a precursor to a full failure of the wiper motor?
Aaron
Roger Hall 01-23-2003 06:23 PM
Same thing happened to my 81 924 na. Remove the switch and clean the ground. I had to replace the switch though.
AaronM 01-23-2003 06:49 PM
OK, stupid question: You mean the steering colum switch, right? Where's the ground point for that?
Aaron
Roger Hall 01-24-2003 09:07 PM
They redesigned them with the 85.5 I am not sure where yours is. If I remove my streeing wheel mine a contact at the bottom.
Britwrench 01-25-2003 12:15 PM
If the intermittent and park don't work you need the intermittent wiper relay. Note that this part is superceeded to a 993 part number and you have to cut one of the terminals off to make it fit the socket.
