Continuity does not nessesarily imply any wire can carry enough current to activate a relay or solenoid.
Old 05-31-2017, 07:58 AM
Ok, I found the red/black wire on a circuit diagram (re/bk). It shows it going through 9 pin connector on pin 7 to the DME on pin 4. It also goes to a 2 pin connector on pin 2. Both of these connectors are in your picture. In addition it looks like it goes to the starter. According to the DME pin out, pin 4 is the start signal.
I believe your DME may be fried. My 944 behaved the same. Unless I was turning the key, it would die. By forcing that pin high, you are faking the DME that you are still trying to start. It's much more forgiving while starting. I've got an old thread somewhere with a link in it for a more modern DME.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Old 05-31-2017, 01:14 PM
Here's the schematic I found.
Old 05-31-2017, 06:06 PM
UPDATE 06-17-17 - Problem Solved !!!!
I finally got a known working DME unit from rothaus. Plugged that one in and made sure everything was hooked up properly and the car started right up and kept idling as it should.
So it looks like if you cross the starter and alternator wires you will fry your DME.
Thanks for all the help and suggestions, I am sure I will be back soon with more things.
Thanks again Englebert
Take care,
Bimmerod
Old 06-17-2017, 10:48 PM
Tags
ignition , relay , solenoid , starter
