| jhowell371 |
05-07-2017 06:08 AM |
Running rough fix
The S2 threw a fit the other day. Running rough with low power it acted like it did when the oxygen sensor came loose. Crawled under there to tighten it up and but it was tight. Checked the connection plug but no change. Swapped out the O2 sensor this morning and she's as good as new :) I tied a string to the old plug and pulled the old sensor out from below. Tied the string to the new plug and pulled it up to the connector. The God's must have smiling on me as I was able to loosen the firewall wire tie and it didn't break.
