Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
1984 porsche 944 explosions
Any help would be appreciated...car turns on fine in the first turn of the key.. it idles fine but then once you press the gas it stutters and then does an explosion in the intake j boot... everything involving the fuel is new(fuel pump, filter, injectors, fuel, fuel pressure regulator ).. also anything involving the spark is new too (coil, rotor, distributor, plugs). My speed and reference sensors are new too...check every line and fixed for a vacuum leak and made sure all lines are routed correctly...
Hers a video of what's happing
https://youtu.be/Uas9cMsu9dA
This is what is coming out the exhaust
Old 06-08-2017, 05:42 PM
That's weird. Could a valve be stuck open and the combustion is going back through the intake?
Old 06-09-2017, 11:18 AM
I don't think so because if I go slowly it doesn't do that, it accelerates, and revs but that to slow to be doing that on the road.
Old 06-09-2017, 11:33 AM
i swear i replied to this thread last night but maybe not
classic lean backfire, if it idles OK then I suspect your TPS is ok but the sudden pop with a quick throttle application makes me think your AFM is worn or sticking.
Old 06-09-2017, 12:06 PM
your average wrencher...
Yeah x2, I have seen a afm door get stuck all the way open...
1986 951 Garrett turbo, Rogue Tuned.
1987 944S chipped, konis, rollbar (traded)
1979 924 total rebuild and blueprinted (sold)
1988 XJ 5in lift,long arms, 4.6 stroker, ax-15 w/ 35s
1995.5 Audi S6 Full RS2 bolt-ons, EFI tuned.
Old 06-17-2017, 03:49 AM
West Central Ohio 45380
plyhammer's Avatar
X3 afm
www.plyhammersparts.com
Old 06-17-2017, 11:34 AM
Tags
944
