1984 Porsche 944 Motor noise
Randomly started making a loud noise last night just out of the blue. Ill attach some videos of it. Cant really tell where the noise is coming from though. Theres a oil leak towards the bottom of the black hosing thats connected to the distributor. (Dont know to much about these cars lol). Any ideas?
https://www.youtube.com/watch?v=aSaMRZN8qHo
Old 06-11-2017, 06:33 AM
remove the alternator belt and then remove the two outer belt covers (7 bolts on top cover, 4 bolts on lower cover), it sounds like one of your belt idlers has died, or your balance shaft belt is very loose and banging the cover.
Old 06-11-2017, 07:00 AM
Patrick
pfarah's Avatar
Sounds painful...
Please follow V2's suggestion and inspect behind the timing belt covers. Also (while you're in there), check the water pump for seized/trashed bearings. Good luck!
1984 944 NA, constant tinkering
Old 06-11-2017, 07:33 AM
Do they have tutorials on here to help me through it?
Old 06-11-2017, 10:28 AM
Clark's Garage Home Page
has all the tutorial you'll ever need
plus youtube if your more of a visual learning you can find plently of video on how to take the timing cover off just search 944 timing belt how to
1984-944 NA (Project)
Old 06-11-2017, 03:53 PM
I was fortunate enough to have thought to take the timing belt covers off the 88S I picked up a while back when firing it up the first time. The PO told me the waterpump was going out. It fired it up and the timing belt started smoking after a few seconds. Waterpump has seized. So from then on, any time I plan on firing up a newly acquired 944's, those covers are coming off beforehand to spot any potential valve killing mishaps.
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 06-12-2017, 06:05 AM
