Motul or Mobil 1 for 924s, is there a difference?
Approaching my next oil change soon some new questions come to mind. I've been using Mobil 1 for ever but the shop I work at now swears by the Motul stuff. The question is, for a 1988 Porsche 924 would it run better with Motul or Mobil 1 and what is the difference?
Old 06-16-2017, 03:26 PM
If you can buy Motul at Walmart, then use it...
Otherwise, take advantage of walmarts Mobil 1 pricing of $25 for five quarts for top notch synthetic protecting.
Plus, Mobil 1 have a rebate for even more savings...
https://mobiloil.com/en/promotion/mobil-promotions
Do it yourself for even more savings!!!
Good luck, George Beuselinck
Old 06-16-2017, 07:43 PM
Motul won't give you any benefits over Mobil-1
Old 06-17-2017, 07:29 PM
Are there any down sides to it or are they pretty much the same thing?
Old 06-18-2017, 09:07 AM
jhowell371's Avatar
I have been using Mobil One for 30 years. After reading about the benefits of zinc for cams and tappets I have decided to start adding a bit (half bottle) of STP to add a bit of zinc in my S2. The remaining STP I mix 50-50 with Mobil One for topping off the oil level as needed until the next change.
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 06-18-2017, 01:19 PM
