mhariush's Avatar
944S Pressure Relief Valve o-rings
Hi all
I need to change the o-rings on my Pressure relief valve, the one that's in the head (944 107 139 00) but can't seem to find the sizes anywhere. Jonnybgood suggested Parker's 2-013 and 2-014 and i got them, but they still stuck out enough that I couldn't get the valve all the way down in the hole. It goes further when there are no o-rings. But I forgot to look and see how it looked when installed. But I assume its supposed to be flush, like when it's in there without any o-rings.
Can someone help me out on this?
Thanks.
Old 10-04-2011, 06:07 PM
yarfk
kfray's Avatar
Item # 45 ? check with Pelican 888-280-7799
see Parts Diagram
------Keith------kfray------yarfk-------
87 944 NA stock 116k
06 Honda Ridgeline 83k
10 Vibe 2.4 AWD (Wife's)
Retired My week consist of Saturdays and Sundays
Old 10-04-2011, 07:36 PM
mhariush's Avatar
Hi
No, that's the wrong schematic. This is for the oil cooler, I'm talking about the relief valve in the head.
Look at part #42. Pressure relief Valve (Pressure reducing valve in the manual)
Old 10-04-2011, 09:44 PM
Comeau Racing
To remove the pressure reducing valve INSIDE THE 16V HEAD, first remove the 3mm allen set screw on the OUTSIDE of the block. Then use a good sized screwdriver to pry up on the side groove of the pressure valve. The 2 O-rings will likely be hard as rock.
PCA since 1985
77 924 MARTINI Edition rescued,SOLD
88 924S Special Edition rescued,SOLD
Comeau Racing Enterprises, Inc. www.comeauracing.com
We do only 924S, 944's, 968's all day, every day.
Old 03-31-2015, 05:52 PM
imprezasvx
service info
does anyone know the part number for the o-rings?
Also there's an installation procedure somewhere online I saw once, anyone have the link?
1990 944 S2 westcoast
X-mechanic
no Porsche specialty tools- yet
Old 06-22-2017, 10:07 AM
O-ring sizing needed
Good luck, George Beuselinck
Old 06-22-2017, 11:59 AM
Tags
944s , o-rings , pressure relief valve
