WTB - 944S AC crank pulley
I need the crank pulley/damper for an S. has rubber separating the inner and outer rings of the pulley.
per PET 944 102 123 02 Bob Cox
Bob Cox 78 930 clone project car. 87 924S resurrect at some point. 84 928S, Ruby Red linen/brown interior - sold ![]() 86 944 turbo my new DE/track car - sold ![]() |
The S has what's known as a "harmonic balancer" and 30yo used ones are likely to be worn and ineffective. Get a new factory one if you can find one or there are a couple of improved aftermarket ones out there, check rsbarn.com.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
yea, finding it hard to find, and appears only a few left in Germany.
does anyone know the consequences/impact of installing non-damper version?
It must do a good job of dynamically balancing the rotating mass as with a regular pulley there has been more nvh reported. Could also prevent harmonics causing early oil pick-up tube, fuel rail or other mechanical failures. I doubt Porsche would have spend time to develop and manufacture such an upgrade if it wasn't required.
