CV came apart: Inner race pops out with axle attached
So I've got a couple axles that are doing this. They are together like normal but then can push the inner race through while together. This seems wrong, I thought the cage is supposed to keep the inner race and bearings in. It doesn't take a tremendous amount of force to cause this to happen. The other side seems to not want to happen though.
One broke like this under acceleration and the other broke on the bench like pictured below.
See Pictures:
These are Cardone Select axles.
85/2 NA with alum arms.
Old 07-08-2017, 06:03 PM
The machining/balls look a bit larger than GNK/Lobro units.
Old 07-08-2017, 07:13 PM
Hmm, well I don't have those to compare to. But the inner race just seems to pop through the center of the cage. I'm under the impression this should be impossible with the boot on and axle in place.
Old 07-08-2017, 07:24 PM
Found your problem...
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 07-09-2017, 09:03 AM
Yeah... I just want to know that if I got proper axles that this should not happen or if it's a normal thing? It doesn't seem normal. From everything I've read the inner race should have to be 90º to get through the ball cage like that.
Old 07-09-2017, 09:27 AM
Not a normal thing.
www.944ecology.com
Old 07-09-2017, 10:57 AM
Politically Incorrect
onZedge's Avatar
I just pulled out my original OEM CV joints I had in a box, and they are assembled as shown in your first photo, so the races are indexed correctly (don't think they would go together if they weren't anyway).
The inner and/or outer race must be really worn out, or your balls are too small.
Sorry, was that a "microaggression"?
Edek
'87 924S
'91 535i
Old 07-09-2017, 11:56 AM
The millennial in me is offended deeply by your triggering
Thanks for the help. I'm sending them back. Going to get some FEQ ones from Ian.
Old 07-09-2017, 12:01 PM
Toofah King Bad
Rasta Monsta's Avatar
Ge****t.
» 1980 931 - Got boost? ♦ 1987 924S - Pro44 ♦ 1987 924S - Junkyard score «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 07-09-2017, 01:23 PM
Originally Posted by Rasta Monsta View Post
Ge****t.
What?
Old 07-09-2017, 11:39 PM
What?
I believe he meant a german adjective, past participle of a verb mean sexual intercourse. Of course, I could be wrong.
www.944ecology.com
Old 07-10-2017, 05:43 AM
Cardone Select is brand new Chinese
Cardone re-man is refurbished OE
I have (2) brand new GKN Joints if you are interested
Where did you buy them from? Should have no problem getting them warrantied,
Old 07-18-2017, 10:59 AM
curtisr
curtisr's Avatar
I wonder if Cardone mixed up the Turbo and, for example, the S one???
1977 924 Guards Red (parted and sold)
1987 924s Alpine White (sold)
1987 924s Kopenhagen Blue (my Lowencash tribute track car)
1987 924s Garnet Red (with FIAMM air horns!)
1982 928 Silver (sold)
Old 07-19-2017, 04:34 AM
there used-to-be a company in Knoxville tn that rebuild CVs by machining for larger balls. they moved to Nashville then went poof.
lobro/gnk every 80,000 miles seems like it is cheaper in the long run compared to perpetual replacement of cheaper yet inferior products.
Old 07-19-2017, 03:21 PM
One more reason to stay away from inferior Chinese-made crap.
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 07-20-2017, 04:41 AM
Tags
1985 944 porsche parts , axle , cv joint , late offset
