944 Ignition barrel
I've had an alarm fitted but the installer can't finish it off because he can't remove the Ignition barrel I've tried it as per the haynes manual but have got no, where its stuck soild. Anyone else had this problem?
Old 01-31-2003, 03:21 AM
Thanks ever so much for that I think that should make it possible to reach the wires. Out of interest is it easy to remove the metal from the colum as the picture?
Old 01-31-2003, 04:45 AM
What year is your 944? I'm trying to figure out why the alarm installer needs to pull the barrel..the electrical switch and wiring is accessible from under the dash.
From November 2012; Precision Porsche Specialist
Sussex UK, +44 (0)1825-721-205
2001-2012 Gerber Motorsport Inc. 206-352-6911
07.15.06 1996 Ducati 900SP. Suprisingly enough, it's red
08.16.09 1999 Kawasaki ZRX1100. Green.
Old 01-31-2003, 07:49 AM
It's a '84,
All the wires for the Ignition are very well tucked away under the dash and we can't get to them (unless there is another way?) He needs to solder into the igntion wires and it has to be very neat (cat1 Alarm)
Old 01-31-2003, 08:00 AM
SoCal Driver's Avatar
Find an installer that has 944 experiance. You can drop the fuse/relay block and do the same thing -- better.
Later model factory alarms break not only the ignition to the coil but the base power to the DME relay. Think about it.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-31-2003, 03:01 PM
ae1969's Avatar
Send a message via ICQ to ae1969
...now that is a great idea
Alex - PCA Polar Region - Boxster Muncher
86' 944 Turbo - Megasquirt - 326 rwhp/340lbft @ 18 psi SOLD
www.edmontonhomelife.com
www.edmontonrealestate.ws
Old 01-31-2003, 03:15 PM
