944 (86) spacer or not to spacer....
that is the question![img]http://forums.pelicanparts.com/uploads26/IMG_04281501867286.JPG[/im
either a spacer, or find 8" wide phonedial wheels off a 1986 944 turbo for the rear.
Factory used a spacer on the rear of the 86 to mount the optional Fuchs, I see no problem as long as you fit longer wheel studs. It's always best to buy the correct offset wheels as you don't have to deal with a spacer or the studs. The studs are a pain to fit on the rear and, if you ever go back to the correct offset, you have to suffer the pain again when you remove them.
Mike A 9TECHNIK | TRANSAXLE ÄRA 1986 944 (Street); 1986 944 (Track); 1986 951; 1989 951 (3.0L 8V); 2000 996 Cab. |
The Eibach spacers I fitted are super quality - no issues!
Good to hear. Do the wheels center caps fit with the Eibach spacers?
