-   -   AFS (AFM) voltage output specs. (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/96422-afs-afm-voltage-output-specs.html)
Shepper 01-31-2003 08:13 AM
Can anyone tell me what the voltage output from the 7 pin should be on the AFS with respect to the RPMs that the engine is running?
For instance, I found an old post where Ahmet talks about taking measuremnts at certain RPMs:
"I did my measurements at idle, 2k rpm, 2300rpm, 2500rpm, 2700rpm, 3krpm, and 3200rpm."
But, he doesn't say what the voltage output was.
The reason I'm asking is because I'm still having problems figuring out a way to correctly calibrate the AFS in my car since the PO messed with it. I had a person drive the car the other day who had driven it before I installed this different engine and he said that there was a noticeable lack of power.
I have checked compression and it was good. I know the AFS is not adjusted correctly and by measuring the output at certain RPMs seems to be the only way to calibrate it most accurately.
