Send a message via AIM to pudge64
Question Help with hood
Anyone, please help!! How do you get the hood up if the release cable breaks??
Old 01-31-2003, 01:47 PM
SoCal Driver's Avatar
Take the cover off the bottom and reach up with a long thin lever and trip the latch from the bottom. It's tricky but it can be done.
If the cable broke at the lever in the car you can use some vicegrips on the cable and pull real hard.
Hugh - So Cal 83 944 Driver Person
NOT a 'real' Porsche -- Its Better!!!!
When was the last time you changed your timing and balance belts and/or cam chain and tensioner?
New Users please add your car's year and model to your signature line!
Never break more than you fix!
Old 01-31-2003, 02:56 PM
Okay i'll try taking the cover off and see how it goes. The cable is broke somewhere under the hood, I already checked to see if I could use vice grips inside the car and i can't, thanks a lot
Old 01-31-2003, 05:13 PM
Got the hood open, thanks
Old 02-02-2003, 12:15 PM
Take note of where the cable routs as you prepare to replace it.
Many reroute it so it hangs up on the head light mechanism which in turn will cause the hood to open when the lights are turned on.
Not much fun when your are doing 65mph!
Old 02-02-2003, 03:20 PM
thanks for all the help, i'll keep that in mind when rerouting it
Old 02-02-2003, 04:11 PM
