Central tube!!
So I'm trying to change my clutch out on my 82 924 I've done everything the book says to do. I'm stuck now. The picture is how much I've gotten it out so far.. I'm curious as to why it is so hard to get out. Any ideas?
Old 08-07-2017, 11:31 AM
plays with toy cars
sausagehacker's Avatar
Put a jack under the oil pan and make it so the weight of the engine isn't leveraging on the inner drive shaft. BTDT
1983 944 - modded everything
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28317
'86 951 - under construction
http://forums.pelicanparts.com/dto_garage.php?do=viewvehicle&vehicle_id=28374
Old 08-07-2017, 01:39 PM
Coeur d'Alene, Idaho
Also, just for verification as "the book" certainly varies - do you have the transmission out of the car? I am literally in the middle of this right now.
Old 08-07-2017, 06:39 PM
And ensure you slide the tranny coupler onto the tranny, not the torque tube. I agree with the above in that it's critical to support the engine, and do it in a way that you can 'adjust' the engine's position, especially on reinstall.
'84 944 - new-to-me DD!
'83 944 - looks like ass, runs like horse - in primer.
'82 931 - roadster project - forever incomplete.
'80 924 - spouse's yellowjacket.
Some wrecks and a 924 racer.
Old 08-08-2017, 07:34 AM
So it is imperative that the transmission comes out completely and NOT with the tube still connected to it? The Haynes has lied to me. Again. Lol. I will disconnect everything then and try that. I appreciate the advice.
Old 08-08-2017, 11:36 AM
Actually I just reread the Haynes and Im Pretty sure it does say remove them separately. It just says it a little​ weird. "Remove the four bolts holding the central tube in place and slide the transmission and Central tube back to allow you to do the next step."
Old 08-08-2017, 11:57 AM
The factory service manual has you remove the transaxle first, then slide the central tube back.
The Haynes manual is a joke. Get the factory service manual if you are going to try to do the work yourself.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 08-08-2017, 12:54 PM
I will do that. Thank you!
Old 08-08-2017, 12:58 PM
The biggest omission from a lot of those old references is that you must rotate the torque tube assembly over 180 degrees to disengage the safety catches in order to get it to slide back far enough. And, yes, the transmission needs to be removed. Impossible otherwise.
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 08-09-2017, 03:56 AM
Yep tranny comes out. Shoot some penetrating oil through the bell housing onto the shift fork pin. You will be pulling that later n they can be stuck.
Old 08-09-2017, 06:01 PM
Okay so I took the transmission out. The central tube SPINS freely. My dad and I pulled it back and noticed that the shaft inside wasn't moving at all. I don't want to mess the groves on the shaft up trying to get it to budge. Any ideas? And also I took you guys' advice and got the factory manual. Told me exactly how to do it. Except for this problem. It's always something...
Old 08-12-2017, 05:09 PM
Alex, did you do this?
Bruce P.
New to me 2011 Cayman Base, LSD, Sport Chrono.
1988 951 totaled and missed
"You're the best I ever had" --JJ Cale
Old 08-12-2017, 07:07 PM
So, the 924 central tube (ake the "torque tube" btw) may not have those locking tabs requiring positioning - my year does not and you just slide it rearward. It also spins freely as you describe - no safety tabs get in the way of anything cause they're not there - just a smooth tube all the way to the trans.
You are not pulling the splined drive shaft out of the engine because it is binding due to the engine leaning and perhaps due to the rear of the torque tube (or front) not supported. SO that is your challenge - have someone lift the torque tube up and down to find the right angle while you are at the rear pulling directly on the splined drive shaft. If the transmission is off the vehicle you will be able to pull directly on the drive shaft and pull its splines out of the engine. Wear leather gloves for grip and careful as if it come out suddenly (mind was easy) it will pile drive your hand into something with enormous force. Obviously due care for vehicle being on jackstand and being under it as well. Use various combinations of lifting on the engine's rear and moving the torque tube. It will come out easily when you find the angle but if its binding, that's enormously strong binding with a 7 foot long lever (the shaft and tube) being out of line.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 08-13-2017, 01:02 PM
^+1
No safety catches/tabs on 924. Also, no shift fork pin.
Engine will tilt down in front and bind drive shaft as mentioned. See my post (and sausagehacker's) about being able to adjust engine angle.
Old 08-13-2017, 08:35 PM
