Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
Coeur d'Alene, Idaho
Options for factory foglamp slot?
So, I've ordered a set of quality lamps with a nice cutoff. If they suit my needs for low beam driving in foul weather, I'd like to replace the factory fog lamps with a pair of quality driving lamps. These *appear* to be close to a stock Hella standard size. So I thought I'd ask if anyone's put their own lamps down there and what did you use?
I'd also like to know if there is tribal knowledge to switch the wiring to allow independent operation of the foglamps/driving lamps whenever I want to use them? Thanks.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 08-12-2017, 10:16 PM
im assuming you are going to be having fog/foul weather lamps AND driving lamps?
easy way would be to hook the existing wiring to your stock fog lamps to your new driving lamps.
then, add some wires to power your new foul weather lights via your side marker lights, by getting some of these electrical terminals...
this way, turning the light switch to position one lights up your ambers and foul weather lights, and you can control your new driving lights with the "fog switch" on the console.
this arrangement will make the new driving lamps flash when you pull the headlight stalk with headlights in down position.
Old 08-13-2017, 06:58 AM
My bad. No, I got high end headlamps (Koitos) which have a very sharp beam cutoff that is useful in fog and snow. I understand they are also the best of the 7" round lamps for beam width. So they may/will fulfill much of the role of a fog beam. Since I'm not expecting to drive this car in foul weather much, I'd rather replace the factory fogs with driving beams for more light down the road.
So, I'd like to be able to have "all on" ability with every lumen working for me on high beam and the power to those factory aux fog lamps is cut off when the high beams are on per Federal standards. I like your "winkie" suggestion a lot.
So I guess lets stick with "what have others put down there in terms of lamps" and I'll ask the wiring question later. For starters, the Hella fogs on my car almost look like a stock lamp directly out of the Hella product line. True?
Doug
Old 08-13-2017, 08:22 AM
ah ok.
somewhere, probably under the dash, there is a relay that blocks out the fog light function when you pull the high beam stalk if the headlights are up...
i believe removing/disconnecting that relay should solve it.
Old 08-13-2017, 08:53 AM
So, just checking again if anyone's been able to install a set of lamps in place of the factory foglamps? I'll eventually find something to graft in there, but if anyone's aware of things on the market, I'd appreciate it. Looking for a driving beam.
May give up and get a set of compact LED lamps to put in there just as DRLs. The factory fogs are kinda pitiful - more of a general blob for looks.
Anyone?
Old 12-23-2017, 03:54 PM
drkshdw's Avatar
I remember somebody, somewhere, at one time, installed yellow fog lights from a Nissan truck and they said they fit perfect. I can't find the thread or pics now (maybe it was here, maybe RL) but it's something I've always kept on my to-do list since my car came without fogs. Anytime I go to the junkyard, I'm always looking for a Nissan truck to lift a set from. They aren't a common item on Nissan's, that's for sure so I've yet to test a set out to confirm but it's something to consider.
Old 12-23-2017, 04:19 PM
Anyone?
https://www.youtube.com/watch?v=vzWZiyrpips
Old 12-23-2017, 07:09 PM
9FF 9FF is offline
Too Many Porsches
9FF's Avatar
An alternative would be to fit Euro bumpers, they have factory H3 halogen driving lights built in and you can still keep your fogs.
Mike A
Current: 1986 951; 1986 944; 1986 944 (Track); 2000 996 (Cab); 2005 CL55 AMG; 2009 GTS V8 (6-Speed).
Past: 1972 RS1600; 1983 E24 M 635 CSi; 1985 308QV; 1985 UR Quattro; 1986 944; 1989 M635 CSi; 1990 560 SEC AMG; 1994 E34 M5 (Track); 2001 461 Puch G; 2002 E46 ACS3; 2006 X308 XJR; 2010 LP560-4 Corsa.
Old 12-23-2017, 07:16 PM
BoxsterGT's Avatar
Porsche Crest
How about a few photos to perk up our interest?
Old 01-06-2018, 11:31 AM
You mean this?
Old 01-17-2018, 12:50 PM
BoxsterGT's Avatar
Porsche Crest
This is a Euro bumper.
How about lamps to fit the USA front valence??
Len
Old 01-17-2018, 01:14 PM
Iíve used these clear driving lights on both my 944 and 951. With new relay harness (thanks IceShark) and 100w bulbs, they really light up a mile down road.
https://www.harborfreight.com/clear-lens-halogen-lights-37349.html
Old 01-17-2018, 05:20 PM
