Coeur d'Alene, Idaho
2nd best way to lock crankshaft?
So, I know the best way to lock the crankshaft for a timing belt service is to buy the $200 tool. But I'm sure folks have come up with alternative ways to do it, so I'm looking for tips. The starter is off, and the clutch housing is off if that sparks any suggestions. My current plan is to finish with the clutch job by next taking the flywheel off and replacing the rear main seal and then putting the flywheel back on. So, I could lock things by using a couple of the flywheel bolts reinserted without the flywheel and zip tying a chunk of rebar through them to torque against in removing the front pulley. Or I could put the flywheel and new clutch on and use something jammed in the flywheel teeth with the starter still out. Etc.
Just thought of something - do I need a reference mark on the flywheel for this job? That would certainly settle it.
Thanks, Doug
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 08-13-2017, 02:31 PM
drkshdw's Avatar
Are you just changing the belts or are you doing the whole shebang? If you're literally just taking the old belts off and putting new ones on, you don't need a flywheel lock. Just set to TDC (pencil method in #1 cylinder since your flywheel is off) and take the old belts off and put the new ones on. Now if you're doing seals and waterpump and oil pump drive gear, etc then you will need a lock and you'll need the flywheel. And you can get the arnnworx lock for $45.
Old 08-13-2017, 03:28 PM
Patrick
pfarah's Avatar
I bought the Arnnworx for @$50 which has worked out quite wonderfully... You could also bite down real hard
Seriously: If you live in Mass, you're welcome to borrow mine. I've got an awesome set of tools
1984 944 NA, constant tinkering
Old 08-13-2017, 04:00 PM
Arnnworx lock for the win. I can't count the number of times I've used mine. Worth its weight in gold.
Oh - as for a pencil in the #1 plug hole. DON'T use wood! One wrong move and it splinters and then you're going fishing through the spark plug hole. No fun. Use a PLASTIC chopstick! Ask me how I know this...
'84 944 - new-to-me DD!
'83 944 - looks like ass, runs like horse - in primer.
'82 931 - roadster project - forever incomplete.
'80 924 - spouse's yellowjacket.
Some wrecks and a 924 racer.
Old 08-13-2017, 08:28 PM
Kind of you to offer, but you made me realize I don't have my hometown on here. So now you can see that about 2800 miles of this great country separate us.
So, Im going to pull the pulley and put an oil seal and O ring behind it. So, I guess I'll be needing to hold things still. Thoughts without a lock tool?
Old 08-13-2017, 08:31 PM
Big pry bar locked into the flywheel ring gear teeth and a gorilla (or reasonable facsimile) to hold it.
Old 08-13-2017, 08:38 PM
jhowell371's Avatar
Bit the bullet and buy one. At least try to borrow one so you do it right. No sense in maybe breaking a flywheel tooth off with a crowbar or some improvised tool. I'll loan you mine if you want. Priority mail will get it to you in 2-3 days if you can stand the delay. Shipping costs back and forth will just about pay for your own though.
Red 84 w/25,xxx miles
Stone Gray 89 S2 w/90,xxx miles
Old 08-14-2017, 04:49 AM
Bradical's Avatar
I mean I totally agree and I certainly wouldnt want to have to deal with it, but I dont know that a few fragments from a #2 pencil would put up much of a fight against the combustion cycle.
1988 924SE
2016 STI
PCA - Florida Citrus Region
https://instagram.com/bradical924/
Old 08-14-2017, 04:58 AM
jhowell371's Avatar
I can't remember where I read the thread but someone broke off a wooden dowel doing the TDC thing. All types of suggestions were offered but I think the head came off in the end. Danger is wood fragments holding a valve open for it to bend or burn. The effects of powdered pencil lead (graphite and clay) is up for discussion as to potential engine damage. All I know is writing (compression numbers, stack # or torque specs, etc.) on aircraft exhaust stacks with a pencil is a no-no. The extreme heat from the exhaust gases cause the carbon from the graphite to harden the steel locally leading to cracking. This is what I was told when I was an aircraft mechanic so I never did it to my planes or anybody else's.
Old 08-14-2017, 07:39 AM
$200 for a crank lock. I made one for my Audi 5000 out of some angle iron when doing the timing belt on it once. I then made the realization that the transmission cases are almost identical. It also fit my 944 perfectly. Cost me $5.. When I picked up the 88S I've been working on about 2 years ago, it came with a nice crank lock tool. I used it to do the belts on it.
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 08-15-2017, 10:58 AM
There are some questionable ways to do it but given how tight you need to get the crank bolt getting the proper tool seems reasonable. $200 really? I think I paid $50 or so, Arnnworks is $45 and Amazon has one for $65-ish. shipped. I found a used one.
1987 928S4
1992 968 cabrio
1994 968 cabrio - Supercharged
Old 08-15-2017, 01:17 PM
Bradical's Avatar
The amount of graphite from writing on something is enough material to locally harden steel? Thats interesting as hell, man. (No sarcasm here just to be clear)
I use the timing marks to set TDC, the OT mark and the bottom slotted mark, and the cam and balance shaft marks if applicable. If that bottom slot isnt perfectly centered in the bellhousing slot its not at TDC, I suppose watching a straw bounce up and down is effective too, but to me its easier to see wether or not that mark is perfectly centered than how high a straw is, for me anyway.
1988 924SE
2016 STI
Old 08-16-2017, 06:11 AM
mhariush's Avatar
The flywheel lock costs like 50 dollars, just get one. Like this (not mine)
http://www.ebay.com/itm/PORSCHE-944-924-S-944-TURBO-951-s2-FLYWHEEL-LOCK-NEW-AFTERMARKET-TYPE-/222600201559?hash=item33d4018557:g:B5wAAOSwbtVZPxE ~&vxp=mtr
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 2006 Cayenne, 80 924 Turbo, 69 Beetle
instagram @mhariush @technikercompany
http://stores.ebay.com/Techniker-Parts/
Old 08-16-2017, 08:37 PM
So, I have a manual transmission - why not simply put it in gear with the parking brake on like I've done with other vehicle crank pulley bolts?
Old 08-26-2017, 06:35 AM
Just thinking out loud
mattdavis11's Avatar
Pinion gear is a weak link in the drive train. I've used a pry bar on the flywheel teeth with success many times, but thought better about trying your method, Idaho. I bought the arnworks tool after ten years of ownership.
91 FJ80
84 Ram Charger (now gone)
Old 08-26-2017, 06:48 AM
Baza's Avatar
I have a 2nd and 3rd best method 2nd method borrow pfarah's lock 3rd buy a second hand lock.
Always start with the cheapest option first
83 NA Gaurds Red ( Home at last)
Holden/Opel Vectra 2002
Old 09-03-2017, 05:49 PM
