-   -   Not starting (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/96723-not-starting.html)
sanjit 02-03-2003 03:34 AM
Not starting
Can anyone help!!!
I have a porsche 944, 88 model.
It started and was running fine a couple of days a ago, however it was snowing the other day, and it worked fine, but then decided not to start. It seems to be intermitent.
There is a spark, but no feul coming through.
Can i ask if anyone has had this problem as i am unsure whether this is a fuel pump problem or it is the fuel pump relay.
Also does anyone know where the fuel relay is situated on the car, as i couldn't locate it in the fuse box. Is this because it is part of the igintion relay?.
AFJuvat 02-03-2003 04:31 AM
Check your fuel pump/DME relay first
It's in the fuse box - days DME right on the side of it.
AFJuvat
