BTERRY1's Avatar
Control Arm to body bolt STRIPPED!
When reassembling i did not even get it to proper torque be for the damn thing stripped. after all the BS with rod bearings, and oil pan gasket now this!! guess i wont be driving it to work tomorrow.
what now? how hard to fix this. if i spend too much more my wife will leave me
Old 11-18-2012, 03:12 PM
flash968's Avatar
if it's the caster block bolt, that's disturbingly common. that stupid nut that is welded in there rips loose. i guess they were serious about 34 and not 35 ft/lb. unfortunately the only real fix involves a welder.
Old 11-18-2012, 03:28 PM
Toofah King Bad
Rasta Monsta's Avatar
Shouldn't be too bad. . .I once found a welder on CL who brought his portable 120v unit to my garage and charged a very reasonable rate.
» 1987 924S Turbo - Got Boost? «
"DETERMINATION. Sometimes cars test us to make sure we're worthy. Fix it." - alfadoc
Old 11-18-2012, 03:48 PM
In the Fires of Hell.....
kdjones2000's Avatar
To answer your question, they have to cut out the sheet metal to expose the internal nut that is stripped, remove that one and replace it with a new one, then weld the sheet metal all back together.
I large PITA; look for someone who is good at welding for this job.
Good luck,
Keith
PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
Old 11-18-2012, 04:08 PM
Custom User Title
mikepellegrini's Avatar
Heli-coil!
I stripped one of the control arm bolts on an 84 NA my son owned, and we used a Heli-coil. It was dirt simple and only took maybe 30 minutes. The kits are kinda expensive (~$50) but they're a lot easier than any other solution. And they're advertised to be stronger than the original threads.
Helicoil Inserts | Helicoil kit
83 944 NA - Black on black
86 951 - Red - SOLD 7/21
16 Ford Expedition
He who hesitates is lost.
Old 11-18-2012, 06:13 PM
BTERRY1's Avatar
Thanks Mike I will look into that
Old 11-18-2012, 09:04 PM
Toofah King Bad
^lolz
Old 11-18-2012, 09:48 PM
Redline Racer
HondaDustR's Avatar
Dr. Porsche succeeded by thinking independently and unconventionally...so will I when fixing his creations!
1987 silver 924S made it to 225k mi! Sent to the big garage in the sky
Old 11-18-2012, 10:12 PM
AFM #725
Gawernator's Avatar
Hit the nail on the head. First headlight cover. Installed in about five seconds. Second cover? 10 minutes+ banging away and cussing to fit it on. Guess they can bend or warp?
Old 11-19-2012, 12:07 AM
Just had this happen - stripped the M10 nut on the caster block. A simple fix, that worked for me, is to just go to a 7/16-20 UNF bolt. I know this is not a non-molesting fix for Porsche purists, but my 951 already has an LS3 in it The 7/16 is just big enough so that you can tap the original welded-in nut directly and the aluminum block has enough slop in the tolerance I didn't even have to remove it and drill it out. The tap slips right through the block. Go slow and use light oil when tapping - it's a hard steel. This actually takes slop out of that caster block assembly and although not metic, it's a larger thread with more thread stress area too it appears from engineering tables.
Old 08-16-2017, 09:11 AM
nothing wrong with that IMO...just the "next size up"...
i think i did the same thing 12 years ago, but don't remember LOL
i have 3/8" bolts on my custom rad frame so im right there with you.
tip: for the future, clean a spot on/near the caster block and make a note in sharpie/paint pen that the bolt is 7/16"/SAE sized so you know which socket/wrench to grab.
Old 08-16-2017, 11:15 AM
TimeSert is the only way to go. They are pricey but far superior to a helicoil
Old 08-22-2017, 07:52 PM
