3 piece OPRV
I'm replacing the oil cooler gasket on my 84 and was wondering do I need the alignment tool if I have the 3 piece OPRV?
Old 09-01-2017, 02:39 AM
Yes. You can buy it at Baum Tools.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 09-01-2017, 02:51 AM
Make sure you get the metal one. The resin/plastic ones can vary too much due to expansion and contraction of the material and not give the correct alignment.
87 944N/A since 1992
87 944S - Near Future Engine Project Car
88 944S - Current Project
84 928S - Restoration Project
Old 09-01-2017, 03:59 AM
Will the the alignments took pelican sells work it looks metal and half the price of the one Baum sells?
Old 09-01-2017, 07:12 AM
should look like this:
Old 09-01-2017, 07:56 AM
They may "look" like metal sometimes because they area black or dark grey ABS type plastic. Just be sure it's a metal one an it should be fine. I'd mic it and make sure it matches the drawing V2 has posted above. The plastic one for the new one-piece units I got a while back was several thousandths off on the critical diameters and caused mine to bind and blew the oil filter seal about one second after I fired it up. Puked 3 quarts of fresh oil on the floor.... Grrrr...
Old 09-01-2017, 09:07 AM
the metal one is heavy for how small it is...must be dense german tool-steel..lol
Old 09-01-2017, 09:31 AM
P218 Oil Pressure Sleeve Alignment Tool for 944
ok i'm going to order this one it looks to be the same as V2 picture thanks guys
1984-944 NA (Project)
Old 09-01-2017, 01:31 PM
Northern Motorhead
wildcat077's Avatar
Surprisingly , they are cheap from the dealer, would be a good time to upgrade to a one piece OPRV , the alignment tool is different but nevertheless required.
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
how cheap we talking because the one piece pelican sells is $400 i know mines not broke so that big chunk of change to replace when mines still works
Old 09-01-2017, 01:49 PM
prevailing theory is the change to the one-piece OPRV was done in the event of a repair where the shop did not have the alignment tool for the original 3-piece type valve.
the 3 piece valve alignment is critical - the one-piece valve pretty much aligns itself.
there are literally millions of other cars on the road with the same style OPRV as the 944 3-piece so it can't be all that bad.
Old 09-01-2017, 02:17 PM
thanks for the input i'll purchase the alignment tool from pelican and reinstall my 3 piece valve and cross my fingers everything goes back together smoothly. I got the rusting old headers off without breaking a single bolt it suck to screw this job up on reinstalling the OPRV out of alignment
Old 09-01-2017, 02:38 PM
Just thinking out loud
mattdavis11's Avatar
You do not need an alignment tool. All you need is a magnet on a stick. Use the sleeve as the alignment tool, and tighten slowly, often checking that the sleeve will freely move in and out.
91 FJ80
84 Ram Charger (now gone)
Old 09-03-2017, 06:02 AM
