gas tank interchangability
I have an '83 944 with the typical full fuel tank strong gas smell which I am led to believe is a crack in the top of the tank. I just bought an '86 parts car which appears to have a plastic tank. Will it fit the '83?
Old 09-05-2017, 09:01 PM
Alexb944's Avatar
Im pretty sure the late offset cars had a larger gas tank so it may not work for you.
The cars we drive say a lot about us.
1987 Porsche 924S - RIP
1985.5 Porsche 944 Lux - Daily Project
2002 Mercedes-Benz C320 Sportswagon - Daily Problem
Old 09-06-2017, 08:04 AM
Hi it's not a direct replacement.
It's been done, but it requires converting your car to use the later-944 type transmission crossbar, your car may or may not have suitable holes to mount it from.
The metal tank in your 83 may be cracked (repairable) but it is more likely the hoses on top of the tank for the evap system are rotted and leaking.
If possible I'd cancel the order for that 86 tank or try to resell it, and drop your 83 tank and fix it and the hoses.
Old 09-06-2017, 08:23 AM
ltfisher
My 88 924S, which shares the same tank as the early 944, was exhibiting the gas fume smell when it was 3/4 or more full. I suspected a cracked tank, but after removing it found the cause was just old leaking evap hoses on top of the tank.
Replaced them and all is well. Hopefully for another 25 years or so....
Old 09-06-2017, 01:26 PM
Patrick
pfarah's Avatar
I wasn't so lucky, the tank was cracked as well as the 15mm vent hose running from the steel tank to the plastic expansion tank.
1984 944 NA, constant tinkering
1983 "Beastie" - Safari Build
Old 09-06-2017, 04:14 PM
Thanks for the replies. I was afraid that would be the case!
Ummm... I bought the whole car... as stated in the original post.
Old 09-06-2017, 05:16 PM
CANCEL IT lol
Old 09-06-2017, 07:12 PM
Back from Beyond
924Board.org :: View topic - Fitting a Late (Plastic) Fuel Tank to a 924S
Rasta's done it. Hope the pics work, but even if they don't this'll give you an idea of what's involved.
'88 944 Auto - project, kinda
'87 944 Auto - died saving my wife
'84 944 5SP - crushed under shop roof during snow storm
All others GONE!
Old 09-06-2017, 09:43 PM
Thanks Slam, looks a bit involved. I will see how bad the old one is when I get it down.
Old 09-07-2017, 04:27 AM
