02 Sensor on Euro Spec Car
Ok this is a question for you DME gurus. I am about to install a wideband sensor and gauge to enable better tuning of my 924s.
Ok so on the Euro spec cars there is a spare plug for the 02 sensor which is not needed as Catalytic convertors weren't used here in the UK until 1993. So the question is if I hook up the 02 sensor to the wiring will the computer be able to use the information and more importantly what would be the benefit or perhaps non benefit to the data received. |
THe stock DME cannot understand the signal output from a wide-band O2 sensor.
