-   -   I just purchased the parts I need for the engine,... (http://forums.pelicanparts.com/porsche-924-944-968-technical-forum/97052-i-just-purchased-parts-i-need-engine.html)
overkill 02-05-2003 11:47 AM
I saved alot of money this time:D I spent like 224 the last time,... which is about what I spent this time around. The thing is that I got 16 valve guides(1st over) as oppose to the 8 I got the last time. I also got an oil seal kit along with the top end gasket set. Not bad. I have a good feeling that everything is going to go smooth this time. I swear,... head for a head,... he screws up mine I'll have his:mad:
I told you guyz that my uncle knows this guy? I told him that it was him and he almost didnt believe me. He apparently does alot of work for my uncle. I showed my uncle the head and he said that the guides are really leaking bad. He said I should take it back to that guy and make him fix his work for free, which I think I am goin to make him do. I'll pay for the additional work but he has to correct his own mistake. My uncle doesnt know whether the leaking guides is the reason for my problem. He said the oil should be blown out through the exhaust. But, i might be leaking enough to the point that it is making its way into the cylinder. What about the intake manifold and breather tube though? How does oil get all the way up in there? The oil is leaking and moving it's way in the opposite direction of the flow of the exhaust and air. How does the oil get up into the manifold and breather tube? My timing being slightly off? During compression the pistion is pushing the oil up in there? I think before I install the head,... I am going to bold done the cam without the gear and set it to ~1.4mm and see how the valve is sealing so I know what it looks like. I think that maybe my intake valves are open a bit during compression and thats how the oil is getting up in the manifold. But, then my compression numbers were nice and high when I did the compression test? I dont know,... I am going to do a leak down once I have the timing set.
951carter 02-05-2003 09:43 PM
WHAT!! All this from "the nicest car on e-bay"!!..................j/k
Sounds like you got blow-by =(
I would sit the head on his lap and tell him you will be back tomorrow to get it! Unless of course he wants to pay you $75/hr to R&R it due to his errors.
Blackfoot 02-05-2003 09:48 PM
i know this has been a royal pain, but it has also given you lots of hands-on experience...i envy you in that.
<img src="http://www.pelicanparts.com/MotorCity/blackfoot/turbo_120%20lighter.jpg">
overkill 02-06-2003 01:08 PM
Ok, here we go,... I got my exhaust guides and they shorted me by one!!!!!!!!! ARGH!!! HEADS WILL ROLE!!!!
overkill 02-06-2003 02:10 PM
Wow, sent them an email about the missing guide and within a few minutes I get 2 emails. One that said "Thank you for your order!" and the other from a sales representative stating he order another for me and I should get it within a couple of days. Thats great.
