Send a message via AIM to pudge64
Angry igling
when the car is cold, the idle jumps from 1000rpm to basically shutting off, then it eventually dies out, it seems to get better when the car warms up, any possible solutions??
Old 02-06-2003, 10:07 AM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
what year car? pre 85.5? Aux Air Valve. TPS. AFM. Vacuum leaks. Bad gas. COIL WIRE@! TDC sensor moved. voltage fluctuations. genital discomfort. oh wait, that's me. throttle stop screw backed out and the throttle body butterfly has worn the throat out. Cloggy injectors. fluctuating fuel pressure. air bypass thiny out of whack. radio on the wrong station.
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 02-06-2003, 10:48 AM
well i have a new coil on the way, could the idling of been a sign of the coil going bad??
Old 02-06-2003, 11:11 AM
todwic's Avatar
maybe, but not likely. I'd try the aux. air valve.
'86 951
Old 02-06-2003, 11:16 AM
well, the new coil will be here tomorrow, so i'm going to have to wait till that gets here cause currently it won't start, after i get it running again i will check teh aux. air valve, it's a 84 by the way
Old 02-06-2003, 11:20 AM
todwic's Avatar
Oooo! Same as mine! You know, you can take your aux air valve (herefortoafterwhen to be called AAV) off and stick it in the freezer for 8hrs. Take it out (grab me a Iceypop while yer in there) and you should see a semi largish opening in it, and it should get smaller the warmer it gets. While you're there, i'd check those hoses for leaks, they get bent at some mean angles in thier lifetime.
'86 951
Old 02-06-2003, 11:26 AM
and if it doesn't get smaller?
Old 02-06-2003, 11:47 AM
FLA944's Avatar
Send a message via AIM to FLA944 Send a message via Yahoo to FLA944
Lucky Fellow !
'83 944 "Guards Red"
New Everything (seems like)
16" 968 Wheels
has never left garage (yet)
Old 02-06-2003, 12:33 PM
todwic's Avatar
Then get a job in porn, and buy a new AAV.
'86 951
Old 02-06-2003, 05:55 PM
both sound like a good idea
Old 02-06-2003, 07:55 PM
