Combination switch question airbag vs non airbag
My cruise control stalk broke off and I want to get another combination switch. There are several, 8 different options. I have an airbag steering wheel but the airbag is disconnected. Do I still need to get an airbag combination switch or can I swap over the airbag clocking spring from the switch I have to the new combination switch?
2010 Cayenne GTS |
Use the clock spring with the airbag style switch.
Good luck, George Beuselinck |
Thanks. I just had found that out, needed to use the just right search words.
2010 Cayenne GTS |
