911Etarga's Avatar
Purchasing(I think) 1989 S2 help please!
I went to look at 1989 944 S2 yesterday with 67,000km's on it. It is originally from Japan but was imported to Kamloops BC in '06. All belts/water pump have been replaced, and there are detailed service records from that point on.
BUT when I started it, the car was litterally shaking! The idle was very rough. It wasn't noisy, and the idle was steady at 1000 rpm and not hunting. The issue was only while idling, the car drives smooth with no issues. After driving it for 15 minutes, the idle was better, but still not perfect.
Any ideas as to what the cause might be? Any tips?
'71 911E Targa
Old 10-28-2017, 09:21 PM
Engine Mounts.
Old 10-28-2017, 10:11 PM
In the Fires of Hell.....
kdjones2000's Avatar
No such thing as an '87 S2. You are probably looking at an '87 S (2.7L, 16 valve).
Not nearly as nice as an S2, as the running gear is the same as the NA cars.
NASA/PCA Instructor: '88 951S - with LBE, Guru chips, 3Bar FPR, 1.3mm shimmed WG, 3120 lbs, 256 RWHP, 15 psig boost
1987 924S 944 SPEC racecar - '88 pistons/DME, short 5th
1987 944S - Restored salvage title, ready to live again
I can fix your late 944 Cruise Control module - PM for details
Old 10-29-2017, 04:47 AM
mhariush's Avatar
Vacuum lines could be one culprit. It's most likely an 87 944S, does it have the 16 Valve engine? Pictures? The S2 came in 1989.
Current: 87 944S Black/Black, 89 944 Turbo S ANDIAL White/Burgundy, 78 924 Black/Black, 2008 Cayenne
instagram @mhariush http://stores.ebay.com/Techniker-Parts/
Old 10-29-2017, 09:41 AM
Balance shafts. Either not connected at all or not set correctly.
Gone but not forgotten: 1971 914 First Car (SOLD) | 1972 914 rust bucket (SOLD) | 1986 944 Turbo (Murdered by a Chevy Truck on the freeway)
Current lineup: 1990 944 S2 Cabriolet - Long term project | 1971 914 - Long term project #2 | 1971 914 - Driver
Old 10-29-2017, 01:39 PM
911Etarga's Avatar
Yep, your right, it is a '89... I have worked him down to $14,000 Canadian, 67,000 kms, Gold exterior, right front fender was damaged and the paint is slightly off but the rest of the exterior is very nice, interior is perfect, some minor sweating from engine, Idles rough but drives very nice, belts and water pump were replaced... pictures to come.
'71 911E Targa
Old 10-29-2017, 02:30 PM
Way too much for a compromised car. Try half that.
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 10-29-2017, 03:17 PM
Pauld_94S2's Avatar
Balance shafts vibrate around 3000 RPM.
Bad motor mounts shake at idle and smooth out above that.
Old 10-29-2017, 04:59 PM
911Etarga's Avatar
Motor Mounts were done 4 years/7000 kms ago. Could it be anything terminal? if a Valve was bent, would it vibrate like that? Also, if you put pressure on the gear lever while driving, there is a little whine.
'71 911E Targa
Old 10-30-2017, 09:09 AM
The mounts could have been done using the very inexpensive, low quality aftermarket parts which are known to fail in 1-2 years vs the much more expensive 15+ year Genuine Porsche mounts.
Bad valve likely wouldn't cause vibration but would cause poor running.
$14000 CAD is still high...There has to be a way to get it under C$10k
Old 10-30-2017, 09:58 AM
Pauld_94S2's Avatar
Low quality/cost motor mounts = $40-50.
Porsche branded original motor mounts = about $200 each.
Exactly what Spencer (AKA v2rocket_aka944) is referring to.
Last set I bought from Paramount Automotive was $187 each.
https://store.paramountauto.com/oem-parts/porsche-front-mount-95137504204/?c=Zz1lbmdpbmUmcz1tb3VudHMmYT1wb3JzY2hlJm89OTQ0Jnk 9MTk4OSZ0PXMyJmU9My0wbC1sNC1nYXM%3D
Old 10-30-2017, 11:27 AM
I test drove an '85 with the balance shafts out of time. It idled fairly smooth but as it revved up the thing buzzed so bad I knew something was wrong. After about 3 miles the vibration coming up the steering column was so bad I couldn't drive it any further! My hands tingled for quite a while after.
Is that a right hand drive car?
Actually, having watched Canadian 944 prices for several years now, that price isn't that far out of line. Maybe a bit high but not much if the condition matches the mileage.
Old 11-02-2017, 05:43 PM
Copyright ©2000 - 2021, vBulletin Solutions, Inc.
