ky951's Avatar
Question CV Joint Assembly Question
Hi. Iím in the process of replacing a torn CV boot and have run into a problem.
I used a puller to remove the joint from the axle and removed the cup washer along with it. My axle seems to be an aftermarket replacement and the cup washer has a ridged inside diameter that matches the spline on the end of the shaft. The joint/washer was a real pain to get off even with a puller. The problem is the washer that came with the new boot kit is too large (slides past the stop) and I donít see a way to get the original back on without damaging the shaft splines. The CV joint itself also looks like it doesnít want to go back on.
Any ideas?
Old 02-09-2003, 07:38 PM
todwic's Avatar
Send a message via AIM to todwic Send a message via Yahoo to todwic
You did take out the circlip first, aye?
*Disclaimer: The person above is actually dumber than he appears.
my web site Torque values maintainance and repairs lots of my rebuild pics weights and measurements
'84 944 auto/ps/ac/cc
'86 951
Providing ignorance one post at a time.
Old 02-09-2003, 10:28 PM
ky951's Avatar
Yes.
Brian
'86 951
Old 02-10-2003, 04:42 AM
