Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
1988 AC compressor removal
The process might be straight forward but I wanted to double check before I went in there and started tearing it apart. The mount bolts sheared off so I need to drill them out but, I want to know if theres anything on top of the compressor that I need to watch out for during removal
1988 Porsche 944
1979 MG Midget
Old 11-04-2017, 09:21 AM
itd be easier to just remove the compressor bracket from the engine.
Old 11-04-2017, 09:48 AM
I'm concerned about all the tubing that I see coming from the top of the compressor. I want to get this thing on a table to drill out the bolts and do some regular maintenance on it. I don't want to end up ripping something apart and having to spend more money replacing hoses and such
1988 Porsche 944
1979 MG Midget
Old 11-04-2017, 10:12 AM
those are the refrigerant hoses...does your ac work or is the system empty?
the only "worry" will be if pressurized freon blows in your face.
Old 11-04-2017, 10:27 AM
And the resulting deterioration of the ozone layer for all mankind!
Good luck, George Beuselinck
www.944ecology.com
Porsche Deconstructor (tm)
We buy 944s and sell 944 parts (845-379-1944)
We rebuild torque tubes and instrument clusters for 944/968/928
Old 11-04-2017, 10:54 AM
kuehl's Avatar
1) Recover any remaining refrigerant in the system to avoid black ops dropping in on your garage in the early morning hours. Have a few cases of Becks on hand just in case.
2) Disconnect the 2 ac lines on the top of the compressor attached to the compressor manifold.
3) Loosen belt tensioner, slip belt of ac clutch pulley.
4) Remove 2 bolts running through ac comp/ alt bracket and drop comp down.
If you ac comp is salvageable, replace o-rings and receiver drier with orings, add refrigerant oil.
AC
Kuehl
1987 911 cab, modified
https://griffiths.com/
Old 11-05-2017, 05:44 AM
