How to fit a flush windshield in a 924 ?
I have searched numerous forums unfortunately the dreaded photobucket has wiped out most of the threads so Im looking for advice and the parts required to fit a late 944 windshield in a 924s
any help appreciated
Gaz
Old 12-01-2017, 09:42 AM
less I know,more I learn
Backyardbodyman's Avatar
You need a new rubber on the windshield channel. The old ones get destroyed when you remove the old glass. I got one from Pelican,it was a nos part from Germany. Took a couple of weeks to get it. Glass shops try to level out the glass with sealer. I'm guessing your windshield channel is the same depth or is it different on the 924
Raymond
Old 12-06-2017, 05:42 PM
Raymond
Old 12-06-2017, 06:04 PM
Raymond,
thanks for that very one of the threads shows two rubbers the one in your picture that goes on the inside which effectively raises the screen up and one that goes on the edge of the screen to the body on the outside, by what I understand the later screens have this internal rubber already bonded to the screen.
would you happen to know the part number for this rubber
cheers
Gary
Old 12-07-2017, 06:15 AM
The outer molding holds in place on it. I don't believe they're available. My new aftermarket glass didn't come with it. My outer molding is going on with sealer
Old 12-13-2017, 06:33 AM
