Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
Washer reservoir - late one fit early cars?
My 924S washer reservoir is cracked (looks like it was repaired once already by PO). I know I can get another one, but I'm curious as to whether the late reservoir (which appears to be a lot smaller, and doesn't hang down behind the valence) is a direct fit to early cars? I know it uses a different pump as well (mounted at the bottom using partial gravity-feed rather than straight suction feed like the early cars). The late pump setup seems like a much better/preferable design as well....
So, anyone know?
Old 12-14-2017, 05:33 PM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
J1NX3D's Avatar
hi Irish,
the late '88< washer bottle will fit. you'll need the motor as well. The early wiring connector only just reaches the motor as its in a different position to the early type.
I fitted one to my '86 944 for the same reason- as I deleted my bumper with the headlight washers I went for the newer, smaller bottle.
Living in the Rest of World
'86 944 8v n/a
Old 12-18-2017, 11:03 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
