Anyone see a spark plug like this one from a NA 944?
I just changed my plugs about a year ago as the original ones in it were quite badly crudded up with a black, non shiny compound of some sort.
I thought i would be terribly clever and go for the four pronged Bosche Supers
But in fact, i have found today that my number 3 cyclinder - counting from the rad and going backwards - was really badly fouled with the same black material.
it's not an oil build up which i have seen before on an old Mercedes. There's nothing wet. It looks like a carbon build up but not the one typically which is sooty.
Any suggestions as to what is going on in number 3?
thanks
MJ in Beirut
Old 12-17-2017, 02:59 AM
petrolhead611's Avatar
Send a message via AIM to petrolhead611
When I took the crankcase off my engine after sudden total loss of oil pressure at 6000 rpm, I saw quite a lot of similar hard carbonlike stuff in the bottom.
1986 924S bought new. Now used for AutoX and street.
Chipped, throttle cam, highflow filter in original airbox/snorkel, 14mm rear swaybar.
Ford Focus 1.8TDCi estate daily driver
Vindicator Vulcan V8 spyder, street legal sports racing car
(300hp,1400 lbs kerb weight) used for sprints on circuits, and hillclimbs
Old 12-17-2017, 05:16 AM
It could just be a leaking injector running that cylinder too rich. You could move the injector and see if it follows it.
1987 944 Summer
2006 E90 Winter
Old 12-17-2017, 05:53 AM
Tired Member
DaddyGlenn's Avatar
That is what I was thinking. I am reviving a car that sat for quite a while and after idling for less than 10 minutes 3 out of 4 brand new plugs have a good bit of black carbon build up. I know the injectors are bad.
Run a couple tanks of fuel with of a good fuel system cleaner cleaner added and see if that helps.
Glenn
Daily Driver - '78 911SC RoW, Track - '85.1 944
Wife's - '00 740iL (Sport),
Support vehicle - '00 Suburban 2500 4x4
Son's - '85.1 944
Old 12-17-2017, 05:58 AM
Did i hear right that there are companies which clean them and give them back to you?
Im guessing injectors are a bit pricey
MJ
Old 12-17-2017, 08:09 AM
MJ
I had mine cleaned by Witchhunter but ended up replacing one anyway. I bought a remanufactured one from our host.
1987 944 Summer
2006 E90 Winter
Old 12-17-2017, 08:25 AM
Tired Member
DaddyGlenn's Avatar
Here is a tech article on how to clean them yourself.
Glenn
Son's - '85.1 944
Old 12-17-2017, 08:57 AM
witch hunter did mine a couple months ago.
if you have a 16 valve, oil can pool around the plugs if the plug seals on the cover have gone south.
Old 12-17-2017, 12:23 PM
But doesn't a leaky injector sound like it can't be cleaned/fixed? If the pot is runnig rich...
Old 12-17-2017, 10:06 PM
If they are leaking fuel through to the intake that might mean they are sticking or cannot close fully and cleaning might help them.
If they leak to the outside (and your car has not burned up) I think they are not fixable and should be discarded.
Check the part numbers too in case someone has put the wrong ones in.
Also check the fuel pressure and check the fuel pressure regulator and damper, these can leak fuel into the intake via the vacuum lines. The FPR might not have vacuum to it or could stick also and deliver too-high fuel pressure.
1987 928S4
1992 968 cabrio
1994 968 cabrio - Supercharged
Old 12-18-2017, 11:27 AM
But if the FPR was teh problem, wouldn't it do that to all the plugs? I mean, wouldnt all the injectors run a little rich?
Old 12-20-2017, 08:16 AM
I suppose, but you might as well at least check the vacuum side.
1987 928S4
1992 968 cabrio
Old 12-21-2017, 07:58 AM
