Porsche Crest Ford Injectors?
I have a 1986 944 NA that has low resistance injectors, I've received mixed opinions regarding weather I can use ford mustang injectors like the bosh ev1 orange tops without messing up the ECU/DME. I realize that the ford injectors are high resistance, but some people have reported good things on them. In addition would removing/modifying the resistor component on the injector driver help? Thanks.
Old 12-21-2017, 08:32 AM
what are you trying to accomplish by substituting injectors?
just looking for low-cost stock replacements, or something performance-minded?
playing with resistors is when your ECU expects a higher-Z injector than what is in place (classic example the 951 has weird 5.5 ohm injectors, people use aftermarket low-z 2.4 ohm injectors and have to add a resistor pack so the injector circuit is back to 5.5 ohm to keep DME happy).
not the case when the injectors are higher-Z than the ECu expects.
i would THINK that new-design high-z (12-14 ohm) injectors would work OK on stock DME because the current output would be 1/5 or 1/6 what the stock injectors require to open, but "you don't know until you try".
Old 12-21-2017, 09:38 AM
Ok cool, I'm just looking for something that's less money than the stock injectors and a little more performance wouldn't hurt
Thanks for the clarification on the resistance thing though. If you happen to know of anyone selling used injectors for the 944 that would be great other wise I'm going to go with the ford injectors and then post the results here.
Old 12-21-2017, 12:07 PM
there's no performance to be found in fuel injectors, as long as the ones you have still work right, and flow enough.
the stock injectors on a 944 are more than capable for even a warmed-up NA's needs (about 180-190hp at higher fuel pressure). but it's likely the stock ones are dirty and could use a cleaning service like from witch hunter or rc engineering.
Old 12-21-2017, 12:33 PM
yeah exactly, in my case the car sat for 7 to 8 years from the previous owner, the injectors were completely clogged with what was gas but is now dirt. Would rather get a new set but not trying to break the bank. I found a set on amazon the resistance in 14 ohm, the lbs is 24 or 250 cc they are the Bosch gen 3 style but from what I've read they are interchangeable with EV1s. Would this be a good option. Thanks for your opinion
Old 12-21-2017, 01:00 PM
Talking
https://www.amazon.com/gp/product/B07426Z87H/ref=ox_sc_act_title_1?smid=A3JQGLYHJQA55P&psc=1
Old 12-21-2017, 01:01 PM
EV1 refers to the connector type, those have the same plug.
they're a nice color too
give em a shot, post back here how they work out. could be a big help for other 944 owners.
Old 12-21-2017, 02:59 PM
for sure, I'm partial to the color as well lol.
I'll definitely post how they work and pictures of the install as well.
Thanks again for the help.
Old 12-21-2017, 03:03 PM
If they are as pictured you can either roll an O ring onto them to use to retain the injector clip or you can safety-wire them to the rail. Please do not run them unsecured.
An 012 O ring fits well I have found and there is enough material to also groove the injector body so the clip can grab onto that as well.
If you have lost injector clips the black BMW version is pretty cheap on Amazon.
1987 928S4
1992 968 cabrio
1994 968 cabrio - Supercharged
Old 12-22-2017, 10:26 AM
Oh ok very interesting, as a matter of fact the clips were lost by the previous owner.
Thanks for letting me know
Now I see what you mean.
Old 12-22-2017, 11:39 PM
So the injectors came in today and after about seven cranks the engine fired up.
It's the first time this engine had run in years but eventually it started idling just fine.
Thanks for the help and support, the injectors seemed to have worked, so far so good.
Old 12-23-2017, 05:18 PM
