Go Back   Pelican Parts Forums > 1- Porsche Technical Forums > Porsche 924/944/968 Technical Forum
Squealing
Now that I have my 924S running, I have noticed a squealing that wasn't there before I replaced my strut inserts. The car sat for some months while I sorted through all of the other issues. Perhaps the suspension bushings have shrunk? They only seem noisy when turning the wheel and backing up or barely moving forward, then the noise abates
Old 12-21-2017, 01:17 PM
Coeur d'Alene, Idaho
The car is most likely sitting at a different angle, so the bushings may be in the process of taking a set. The other (and I hope wrong) thought is that on new suspension bushings, people will sometimes tighten them with the suspension in full droop on jacks, then let the car down and promptly tear every bushing rubber part free the first time they drive over a good bump that brings the suspension to full compression. They're designed to be tightened on the ground and then move through a few degrees of suspension movement up and down from that center.
I wouldn't worry too much. If it bugs you, shoot some silicone on them one at a time until you find the culprit.
84 944, 87 Vanagon, 88 Mitsubishi Van Wagon, 88 Supra Targa, 1990 Audi 90 20V Quattro sedan, 1992 Lexus LS400, 1993 LandCruiser, 1997 LandCruiser, 2017 Subaru Outback.
Old 12-21-2017, 06:45 PM
Have 944, will restore
mazdaverx7's Avatar
Have you checked to make sure that none of the brake dust shields are making contact with a brake rotor? Squealing while turning and squealing when backing up or at low speeds are common signs that a dust shield got ever so slightly tweaked and is making contact with a rotor.
85.5 944 Guards Red M456 5spd
06 BMW 330xi 6spd/ 92 Miata 5spd
04 RX-8 Nordic Green 6spd/ 01 MR2 Spyder 5spd
04 RX-8 Brilliant Black 6spd 86 Corvette 4+3
85 RX-7 Ocean Blue 5spd /80 RX-7 LS 5spd
Old 12-22-2017, 02:38 AM
