930s rule the wasteland
h20cooled7's Avatar
Send a message via AIM to h20cooled7
fuse box contacts?
Sooooo right parking lights go in and out. not the grounds, cleaned them all. Chasing all kinds of gremlins and its the damn fuse box contacts along with ceramic fuses. Anybody have a safe method of cleaning the contacts in the box.
1980 930 Turbo
1993 Corrado
1983 944
1984 944
2001 VW golf TDI
Old 12-21-2017, 03:40 PM
kevingross's Avatar
I'd used a contact cleaner such as Wurth's Kontact OL, along with a gentle scrubber such as a small metal brush or crocus cloth. You do want to get rid of corrosion, but don't want to tear out good metal. I wouldn't clean to the point of bright shiny metal: normal surface oxidation will return anyway. Just to the point of removing crud-level corrosion / oxidization.
Also check the connection of wires to the fuse holders, make sure things are clean and tight. Good luck!
Kevin
Catellus Engineering
catelluseng@gmail.com
http://www.catellusengineering.com
Old 12-21-2017, 06:07 PM
